intake gasket
Old Jan 4, 2007 | 06:29 AM
koa's Avatar
koa
Default intake gasket
will a bad intake gasket casue my engine to surge up high. When i start it up it goes to redline then i have to turn it off. This all happened after i installed a new intake mani.
Old Jan 4, 2007 | 06:42 AM
Syndacate's Avatar
Default Re: intake gasket (koa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa &raquo;</TD></TR><TR><TD CLASS="quote">will a bad intake gasket casue my engine to surge up high. When i start it up it goes to redline then i have to turn it off. This all happened after i installed a new intake mani. </TD></TR></TABLE>
I believe you are talking about the intake manifold gasket?
I've seen them and especially the IACV gaskets (when gone bad) cause high idles and surging idles.
Though I've never seen anything to the redline about that...
Make sure your butterfly isn't jammed.
Old Jan 4, 2007 | 06:58 AM
koa's Avatar
koa
Default Re: intake gasket (Syndacate)
at first i thought it was the iacv but i tested it and it was good. Ill be replacing them this weekend. Do i need honda bond for the intake mani gasket???
Old Jan 4, 2007 | 07:02 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa &raquo;</TD></TR><TR><TD CLASS="quote">at first i thought it was the iacv but i tested it and it was good. Ill be replacing them this weekend. Do i need honda bond for the intake mani gasket???</TD></TR></TABLE>
Why not just take a razor and shave off any remaining parts of the gasket and put a new gasket on?
EDIT:
Oh wait, is that a rubber gasket or a metal one?
Old Jan 4, 2007 | 07:09 AM
koa's Avatar
koa
i wanna say metal by the looks of it
Old Jan 4, 2007 | 07:52 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa &raquo;</TD></TR><TR><TD CLASS="quote">i wanna say metal by the looks of it</TD></TR></TABLE>
Blah, then ignore that last post of mine.
Old Jan 4, 2007 | 07:57 AM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Blah, then ignore that last post of mine.</TD></TR></TABLE>
or all of them
If the intake gasket has a leak, the idle will surge, just like if you had a vacuum leak. Did you torque everything down within spects and used a new gasket?
Old Jan 4, 2007 | 10:58 AM
koa's Avatar
koa
Default Re: intake gasket (DeadEnd9009)
no hell no but i will this time around!!!!!!!
MechEng
Feb 2, 2012 04:01 PM
Nicaraguense13
May 26, 2006 04:07 AM
Shizznaz
Sep 2, 2005 08:07 AM
EdLeake
17
Feb 23, 2004 09:08 AM
The Brown Kid
Aug 2, 2002 03:21 AM
