intake gasket
Old 01-04-2007, 06:29 AM
koa
koa's Avatar
Default intake gasket
will a bad intake gasket casue my engine to surge up high. When i start it up it goes to redline then i have to turn it off. This all happened after i installed a new intake mani.
Old 01-04-2007, 06:42 AM
Syndacate's Avatar
Default Re: intake gasket (koa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa &raquo;</TD></TR><TR><TD CLASS="quote">will a bad intake gasket casue my engine to surge up high. When i start it up it goes to redline then i have to turn it off. This all happened after i installed a new intake mani. </TD></TR></TABLE>
I believe you are talking about the intake manifold gasket?
I've seen them and especially the IACV gaskets (when gone bad) cause high idles and surging idles.
Though I've never seen anything to the redline about that...
Make sure your butterfly isn't jammed.
Old 01-04-2007, 06:58 AM
koa
koa's Avatar
Default Re: intake gasket (Syndacate)
at first i thought it was the iacv but i tested it and it was good. Ill be replacing them this weekend. Do i need honda bond for the intake mani gasket???
Old 01-04-2007, 07:02 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa &raquo;</TD></TR><TR><TD CLASS="quote">at first i thought it was the iacv but i tested it and it was good. Ill be replacing them this weekend. Do i need honda bond for the intake mani gasket???</TD></TR></TABLE>
Why not just take a razor and shave off any remaining parts of the gasket and put a new gasket on?
EDIT:
Oh wait, is that a rubber gasket or a metal one?
Old 01-04-2007, 07:09 AM
koa
koa's Avatar
i wanna say metal by the looks of it
Old 01-04-2007, 07:52 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa &raquo;</TD></TR><TR><TD CLASS="quote">i wanna say metal by the looks of it</TD></TR></TABLE>
Blah, then ignore that last post of mine.
Old 01-04-2007, 07:57 AM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Blah, then ignore that last post of mine.</TD></TR></TABLE>
or all of them
If the intake gasket has a leak, the idle will surge, just like if you had a vacuum leak. Did you torque everything down within spects and used a new gasket?
Old 01-04-2007, 10:58 AM
koa
koa's Avatar
Default Re: intake gasket (DeadEnd9009)
no hell no but i will this time around!!!!!!!
MechEng
02-02-2012 04:01 PM
Nicaraguense13
05-26-2006 04:07 AM
Shizznaz
09-02-2005 08:07 AM
EdLeake
17
02-23-2004 09:08 AM
The Brown Kid
08-02-2002 03:21 AM
Quick Reply: intake gasket
