99-00 OEM Foglight problems
Old Jan 3, 2007 | 01:57 PM
Mr.EM1's Avatar
Default 99-00 OEM Foglight problems
So I ordered the OEM replica foglights off of JHP. And started to mount them and wire them to the car. The foglights themselves mounted perfectly but nothing is wiring correctly, according to the directions. I don't think I received the right wiring harnesses, so I called JHP and they told me that they were indeed the right harnesses.
Here are some pics of the harnesses that i got:
Switch Harness
Foglight Harness
Those of you who have these same foglights, do any of these wires and connections seem familiar? I hope i got the right ones
Thanks for any help,
-Eric
Old Jan 3, 2007 | 02:06 PM
jtchinoy's Avatar
holy wow... those look so wrong
I just put in my dash wire harness today and stared at my engine bay one for a while. Those are totally different from OEM.
Mine was genuine OEM though, so maybe yours hooks up differently.
Old Jan 3, 2007 | 02:40 PM
Mr.EM1's Avatar
Default Re: (jtchinoy)
Anybody order theirs through JHP and if so does yours look like mine? I'm gonna give JHP a call tomorrow.
Old Jan 3, 2007 | 04:06 PM
lamboextreme's Avatar
Default Re: (Mr.EM1)
i ordered mine from password jdm and they do look different mine have connectors and the only loose wire is for the grounds and your connectors do look different also.
Old Jan 3, 2007 | 04:49 PM
Si_chRis's Avatar
Default Re: (lamboextreme)
Bought mine from JHP, it looks right to me. The clear connector in the first pic goes to the switch. The brown connector goes to the under dash fuse box, ground the grounding wire and the red clear rubber part is power.
And the clear rubber red wire from under the dash connects to the clear rubber red wire on the driver side, then goes to the fog light, then follow the wire to the other foglight.
then it should then go to the relay which is the black box, then from there to the battery terminal.
I wired mine up fine, just ask me if u have problems...it took me a while until I laid eveything out but I eventually got it...good luck
*edit* You will have to crimp the rubber clear wire connector part
Old Jan 3, 2007 | 05:34 PM
Mr.EM1's Avatar
Default Re: (EM1_ChRiS)
Ah thank you very much, the instructions they gave me weren't all that detailed. I'll let you know if i have any problems.
Old Jan 3, 2007 | 05:37 PM
HCRX311's Avatar
I just got my OEM set acouple days ago, not replica and it looks totally different then those. I can get pics if you need it.
Old Jan 3, 2007 | 05:42 PM
Mr.EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS &raquo;</TD></TR><TR><TD CLASS="quote">
ok, so what goes to the battery terminal?
Old Jan 3, 2007 | 05:50 PM
Si_chRis's Avatar
You connect the red wire with the round brass washer look alike thing to the Postitive side terminal. The wire should be coming from the relay.
Old Jan 3, 2007 | 05:57 PM
deadline's Avatar
this is for EG wirings but follow it for your EK
Old Jan 3, 2007 | 07:08 PM
2coupes's Avatar
that's everything, assuming you have the switch
Old Jan 3, 2007 | 10:34 PM
jtchinoy's Avatar
yeah my genuine OEM plugged right in
There were plugs lying around to plug in to and holes to plug clips in to.
Old Jan 3, 2007 | 11:14 PM
BlueIntegraBoy's Avatar
Default Re: 99-00 OEM Foglight problems (Mr.EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
Switch Harness
Left: ground
Middle: goes to fusebox accessory slot
Right: goes to wire that runs through firewall to fog harness
Goes to switch
Foglight Harness
Left: relay plugs into it
Right: positive terminal of battery
Goes to wire that runs through the firewall to the switch harness
Old Jan 4, 2007 | 10:32 AM
Mr.EM1's Avatar
Thanks a bunch everyone, gonna go try rewiring everything again. Will let you know how it turns out.
integratyper1990
Jun 5, 2011 04:37 PM
fool11
Northern California (Sales)
Dec 10, 2008 08:50 PM
Eran
Northwest (Sales)
Jun 23, 2008 11:04 PM
sinfulj32
Aug 24, 2005 09:43 PM
SoyaBean
Jan 26, 2005 06:08 PM
