99-00 OEM Foglight problems
So I ordered the OEM replica foglights off of JHP. And started to mount them and wire them to the car. The foglights themselves mounted perfectly but nothing is wiring correctly, according to the directions. I don't think I received the right wiring harnesses, so I called JHP and they told me that they were indeed the right harnesses.
Here are some pics of the harnesses that i got:
Switch Harness
Foglight Harness
Those of you who have these same foglights, do any of these wires and connections seem familiar? I hope i got the right ones
Thanks for any help,
-Eric
Switch Harness
Foglight Harness
-Eric
holy wow... those look so wrong
I just put in my dash wire harness today and stared at my engine bay one for a while. Those are totally different from OEM.
Mine was genuine OEM though, so maybe yours hooks up differently.
Re: (Mr.EM1)
i ordered mine from password jdm and they do look different mine have connectors and the only loose wire is for the grounds and your connectors do look different also.
Re: (lamboextreme)
Bought mine from JHP, it looks right to me. The clear connector in the first pic goes to the switch. The brown connector goes to the under dash fuse box, ground the grounding wire and the red clear rubber part is power.
And the clear rubber red wire from under the dash connects to the clear rubber red wire on the driver side, then goes to the fog light, then follow the wire to the other foglight.
then it should then go to the relay which is the black box, then from there to the battery terminal.
I wired mine up fine, just ask me if u have problems...it took me a while until I laid eveything out but I eventually got it...good luck
*edit* You will have to crimp the rubber clear wire connector part
Re: (EM1_ChRiS)
Ah thank you very much, the instructions they gave me weren't all that detailed. I'll let you know if i have any problems.
Re: (EM1_ChRiS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS »</TD></TR><TR><TD CLASS="quote">
ok, so what goes to the battery terminal?
Re: 99-00 OEM Foglight problems (Mr.EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1 »</TD></TR><TR><TD CLASS="quote">
Switch Harness
Left: ground
Middle: goes to fusebox accessory slot
Right: goes to wire that runs through firewall to fog harness
Goes to switch
Foglight Harness
Left: relay plugs into it
Right: positive terminal of battery
Goes to wire that runs through the firewall to the switch harness
Switch Harness
Left: ground
Goes to switch
Foglight Harness
integratyper1990
06-05-2011 04:37 PM
sinfulj32
08-24-2005 09:43 PM
