CODE 10 : intake air temp.
Old Jan 2, 2007 | 10:05 PM
nello a.'s Avatar
Default CODE 10 : intake air temp. SOMEBODY
just swapped this motor . d15z1 into a 94 or 95 civic ex. p28 ecu. ex harness. did not throw this code in other engine. it has a d16z6 intake manifold. did i hook up a sensor wrong? manifold causing this somehow? i double checked the sensors. one long flash is ten-correct?
advice is appreciated.
Modified by nello a. at 12:39 AM 1/3/2007
Old Jan 2, 2007 | 11:31 PM
nello a.'s Avatar
never dealt with this code. anyone?
Old Jan 3, 2007 | 01:44 AM
nello a.'s Avatar
Default Re: (nello a.)
hgfv
Old Jan 3, 2007 | 05:06 AM
Andres-eh2's Avatar
z1 is a VX motor? if so why would you run a p28 when the motors are completely different?
Old Jan 3, 2007 | 07:23 AM
EJgsr's Avatar
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">z1 is a VX motor? if so why would you run a p28 when the motors are completely different?</TD></TR></TABLE>
it is a close MAP but it is a little different. are you using the same harness that came with the car??
Old Jan 3, 2007 | 08:44 AM
VtecnTurbo's Avatar
Default Re: (USDMej1)
the sensor could be bad.
take your sensor that was working fine out of your old manifold and put it into the new manifold.
Old Jan 3, 2007 | 10:09 AM
Andres-eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">it is a close MAP but it is a little different. are you using the same harness that came with the car??</TD></TR></TABLE>
The purposes of vtec and vtec-e are completely different. Now if the purpose is just to drive then its ok if it runs fine, but for performance
Old Jan 4, 2007 | 09:15 PM
nello a.'s Avatar
it is not a performance engine. i dont think any sohc is a performance engine. for anyone that may search this later-
SOLUTION: sensor was melted. it worked on previous engine? go figure?
b16ajdmrex
Jul 26, 2010 06:35 PM
SoHc94
Sep 11, 2006 08:58 PM
kidrolla
Sep 4, 2005 12:31 PM
PuiPui
May 17, 2005 08:18 PM
splitime
Sep 7, 2002 04:21 PM
