does this sound like a vacuum leak?
There is a hissing sound around my brake master cylinder and I can't find exactly where it's coming from. But I notice that when I accelerate, the sound seems to go away and then come back when I let my foot off the gas. Does this seem like a vacuum leak? If so, how can I find it and fix it? Any help would be greatly appreciated.
Unless the car is idling up (fully warm) past 900rpms or so, then its not a vacuum leak. You can check the vacuum hoses around there and/or spray carb cleaner and if there is a leak it will make the car idle even higher.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrich33 »</TD></TR><TR><TD CLASS="quote">sounds like the brake booster has gone bad</TD></TR></TABLE>
x2
x2
Its not the brake booster gone bad. Your brakes wouldnt work very good and from what you said the pedal seems to be working right. Really sounds like a vacuum leak. I would try what is said already about the brake clean. Just spray it around by the sound until the idle changes and youve pinpointed the leak. Good luck
Thanks dc5_integra. I also think it is a vacuum leak.
But wouldn't a vacuum leak cause my idle to be unstable. For the most part, my idle is stable with an occasional(not very often) slight increase in rpm. Is this an indication of a vacuum leak? The hissing is very loud and can even be heard from within the car.
hondas/acuras with vacuum leaks always have a high idle. Does it only do it at idle or all the time even under load? Do you have an after market air filter like a K&N cold air intake? Because those tend to be kinda loud too.
The hissing is during idle but goes away when I accelerate. But once I let off the gas, it comes back. I know it is not my intake because I know the whistling sound it makes and I am hearing a hissing sound around the master cylinder area.
DUKE LADUKE
25
May 10, 2011 09:21 AM
