HeadLight Problem
I am having a headlight problem in my 92 CX the driver-side low beam will not work but the high-beam works fine. Anybody have any possible solutions to the problem all help is appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dillywong »</TD></TR><TR><TD CLASS="quote">if not the bulb, then check the low beam relay.</TD></TR></TABLE>
More than likely the bulb. I've never seen one of these relays fail, but it's definitely possible.
1. You didnt secure the plug that goes to your bulb tight enough while installing them.
2. When you turn your high beams on and it lights up then your bulb is bad. If not then go back to # 1.
3. you might have installed a bulb with a higher wattage than 55 and you just fried one of your harness. If you keep the other one, you will fry the other harness too.
gen5accstilez
Honda Civic (2001 - 2005)
Sep 3, 2007 08:13 PM
Jacen
Mar 22, 2006 10:51 PM
