Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
headlight problem
Old Aug 11, 2008 | 08:12 PM
xaznxdrgnxboix's Avatar
Default headlight problem
hi my friend has a 07 si and had after market hids installed a while back and after market yellow fogs and just today her passenger side headlight and foglight wont turn on. anyone might know the problem thanks.
Old Aug 11, 2008 | 08:15 PM
phootbag's Avatar
Default Re: headlight problem (xaznxdrgnxboix)
I would probably start by checking the integrity of and the installation of the aftermarket parts.
Old Aug 11, 2008 | 08:54 PM
Default Re: headlight problem (phootbag)
we installed everything fine its been working for almost a year now lol any other things i should check
Old Aug 11, 2008 | 09:37 PM
phootbag's Avatar
Is it possible that both bulbs are bad? It may be possible one went bad but the owner did not realize it until the second bulb was found inop.
Old Aug 12, 2008 | 11:14 AM
oh ok that makes more sense lol but if the bulbs went bad would it cause the passenger side fog light to go out? cause only the passenger side headlight and fog light don't work
Old Aug 12, 2008 | 12:46 PM
ChargedSI's Avatar
Check your relay. I had the same problem with my HID's and found my relay had failed.
Old Aug 12, 2008 | 02:36 PM
2008fijibluesi's Avatar
Default Re: headlight problem (ChargedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChargedSI &raquo;</TD></TR><TR><TD CLASS="quote">Check your relay. I had the same problem with my HID's and found my relay had failed.</TD></TR></TABLE>
It did it's job then!
jtthwaits
Mar 5, 2011 05:40 PM
CivicVelox17
Jan 2, 2007 10:11 PM
GSblueRacing
May 28, 2004 06:27 PM
Accorddrver
Apr 27, 2004 09:41 AM
