okay..peepo SMOG question (ca)
Old Jan 2, 2007 | 04:14 PM
deadline's Avatar
Default okay..peepo SMOG question (ca)
just went to smog...and HC (hydrocarbon) is a lil high off by couple digits... failed twice.....what can i do to lower the numbers ? is it that my cat needs to be replace or timing...or fuel ? help me out.........got ticket for modified intake now have to go to state ref
i failed twice at state ref..........stock single cam d16z6
if your in northern kali bay area leave a # jdm_geo_metro_209@yahoo.com
Old Jan 2, 2007 | 05:42 PM
deadline's Avatar
bump.....?
Old Jan 2, 2007 | 06:51 PM
fishnfst's Avatar
How old is your cat? My car passed exactly on the money with the cat warmed up.. If I let the cat cool for 10-15 minutes before testing it would fail.. YOu mjight just need to borrow a fresher cat...
How is everything else with the motor running? How is the comopression and vacuum? When was the last time you did a tuneup?
If you were running it modified you may have burned up your cat already...
Old Jan 2, 2007 | 06:57 PM
deadline's Avatar
Default Re: (fishnfst)
motor runs fine...just did tune up and it has about 210,000 miles ..is it time for a new cat......
Old Jan 2, 2007 | 07:02 PM
jay_cue's Avatar
Default Re: (deadline)
Post a copy of your smog. Did you fail anything else? What mph did you fail your nox?
Timing can effect your nox, and your a/f too. If your lean nox will go up.
When I went to ref my car, I failed the 15 mph nox by a little. The inspector was col, and ran my car for a little bit to warm the car up more. It passed the second time he ran my car.
Edit: reading owns me. I reread the original post, its your hc that you failed. But try to post up numbers. Having the cat really hot should bring down the numbers down a little still
Modified by whal3_p3nis at 8:22 PM 1/2/2007
Old Jan 2, 2007 | 07:08 PM
deadline's Avatar
Default Re: (whal3_p3nis)
it fail both 15 and 25 mph...
15mph max93 meas120
>hydrocarbons
25mph max59 meas70
Old Sep 19, 2009 | 07:02 PM
DJ_Double_R's Avatar
New User
Default Re: okay..peepo SMOG question (ca)
i just tried to smog my car and got high hc also
at 15 mph max is 92....my car 333
at 25 mph max is 59 ... my car 147
Old Sep 19, 2009 | 08:03 PM
Speed_1's Avatar
whens the last time you change the plugs, wires, cap, rotor?
Old Sep 19, 2009 | 08:21 PM
New User
about to do all that on monday and get it re smogged and see if that helps ran some seafoam and that guaranteed to pass stuff.
Old Sep 19, 2009 | 08:59 PM
jdm_sir2's Avatar
Check timing also u could be running a little rich....
GsR-Freak
Apr 3, 2005 11:40 PM
ekb16
Mar 1, 2005 09:06 PM
sitrucjr
Mar 20, 2004 01:37 AM
Canuk_SiR
Oct 30, 2003 08:50 AM
Thrillhouse
Jul 22, 2003 07:55 AM
