Do i NEED to replace my good head gasket and head studs
Old Jan 2, 2007 | 03:24 PM
drumminforev's Avatar
Default Do i NEED to replace my good head gasket and head studs
I am taking the head off to do some block work. It is neccessary to replace the head gasket and head studs, or can i reuse all.
any special proceedure for retorquing head studs if usable?
I will be installing ctr pistons in a b16a2. What size head gasket to buy if neccesary?
Old Jan 2, 2007 | 05:20 PM
y7turbo's Avatar
Default Re: Do i NEED to replace my good head gasket and head studs (drumminforev)
replace the gasket and reuse the studs
Old Jan 2, 2007 | 05:24 PM
Jimmy's Avatar
Global Moderator
Default Re: Do i NEED to replace my good head gasket and head studs (y7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo &raquo;</TD></TR><TR><TD CLASS="quote">replace the gasket and reuse the studs</TD></TR></TABLE>
A must, Right now would be a good time to upgrade the studs
Old Jan 2, 2007 | 05:27 PM
Jimmy's Avatar
Global Moderator
Default Re: Do i NEED to replace my good head gasket and head studs (Jimmy)
arp's are on sell in the marketplace
Old Jan 2, 2007 | 05:29 PM
wheelmanbg's Avatar
definitely replace the gasket
Old Jan 2, 2007 | 05:34 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">I am taking the head off to do some block work. It is neccessary to replace the head gasket and head studs, or can i reuse all.
I will be installing ctr pistons in a b16a2. What size head gasket to buy if neccesary?</TD></TR></TABLE>
Replace the head gasket with a stock one, you'll be fine. You can reuse the headbolts but if you ever take them out again I'd replace them. Head studs are nice but not necessary for your build. Just follow the torque sequence shown in the shop manual.
Old Jan 4, 2007 | 09:10 AM
Default Re: Do i NEED to replace my good head gasket and head studs (00Red_SiR)
K thanks. Anyone have a link to good priced oem headgaskets?
Old Jan 4, 2007 | 10:33 AM
junior40er's Avatar
kragen for 25bucks.
Old Jan 4, 2007 | 11:08 AM
Default Re: Do i NEED to replace my good head gasket and head studs (junior40er)
show me this, its 69 on kragen i just check... 2000 civic si
Old Jan 4, 2007 | 12:46 PM
EG2Driver's Avatar
hondapartsdeal.com or majestichonda.com will have the cheapest OEM parts for sure.
Old Jan 4, 2007 | 12:55 PM
walsh22's Avatar
Default Re: Do i NEED to replace my good head gasket and head studs (DeadEnd9009)
dweff get a new head gasket or youll have an oil leak.. try autzone or a place lyk that for the gasket it will be lyk 40 bucks oppose to lyk 130 at a dealer
Old Jan 4, 2007 | 01:39 PM
jtchinoy's Avatar
check your local performance shop?
I got my gaskets for a fair deal from a local shop not necessarily cheaper than majestic, but I got it 2 days later and $8 cheaper than from the dealer.
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
Dartanian
Jun 13, 2006 10:40 PM
Squirtin EGsr
17
Sep 26, 2005 09:13 PM
chop suey
Nov 9, 2004 05:47 PM
