B18 Swap, hoses and lines HELP ME OH MY!!!!!
Old Jan 2, 2007 | 02:08 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default B18 Swap, hoses and lines HELP ME OH MY!!!!!
ok, after fighting WW3 with the engine mounts, I'm down to the nitty gritty.
1991 b18a1 swap into 93 civic hatch.
help me figure out where these lines go. I'm assuming each of the circled lines just go to manifold vacuum but just in case I wanted to post here.
Also, I'm using the stock civic auto radiator with the swap but none of the main hoses match up. the 91 LS or the 93 civic lines. my bottom hose reaches just fine but the opening is too small. the top one doesnt reach far enough. what lines do I need??
Also, again...my stock civic fuel return line doesnt fit over the nipple on the LS fuel rail?? wtf?? damn nickel/dime stuff...
here's a pic of the lines:
Old Jan 3, 2007 | 04:34 AM
stackz's Avatar
Community Builder
Default Re: B18 Swap, hoses and lines HELP ME OH MY!!!!! (stackz)
bump, anyone ?
Old Jan 3, 2007 | 04:47 AM
B18CivicEH2's Avatar
wow....i also have a 93 hatch and droped a B18B LS motor and the weird thing is that i didnt run to that prob you have with the radiator hoses....mine were perfect, although i remember a while back ago, i was on the Hasport website and they give you all the info you need...i remember it said something about using a DEL SOL DOHC VTEC hose for the radiator but can remember if it was the top or bottom....check their site out....for some reason its not workin on my laptop right now..
check where it says TECHNICAL INSTRUCTIONS on the top right...look under your make and model of car and select your swap..
now, with the hoses to the TB i cant help you there because i changed mine with a spare GSR one i had and i looks different...sorry
Old Jan 3, 2007 | 04:59 AM
Andres-eh2's Avatar
Green - To Charcoal canister
Red - MAP
Yellow - Doesnt Matter
Purple - Not sure.
If you wanted to run all those vacuum lines correctly you need these two sensors i believe from the donor teg (mounted on the firewall) but its pointless. your harness will not make it work. those lines on my setup were taken off the manifold.
You will need to buy bseries radiator hoses as well. Ive used 93 LS on mine with no probs. Go to an autoparts and buy a fuel line one size bigger. not a big deal.
Old Jan 3, 2007 | 05:05 AM
stackz's Avatar
Community Builder
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">Green - To Charcoal canister
Red - MAP
Purple - Not sure.
You will need to buy bseries radiator hoses as well. Ive used 93 LS on mine with no probs. Go to an autoparts and buy a fuel line one size bigger. not a big deal.</TD></TR></TABLE>
ok, I got the first two correct then
for the yellow one, can I just run that to manifold vacuum??
anyone know on the purple??
I'll stop by and pick up the LS lines this afternoon.
I was thinking of just getting the slightly larger fuel line but then wont the opening be waaayyy too big on the chassis side?? I mean I'm sure I could get an adjustable hose clamp but wont the fuel pressure blow it off or something??
Old Jan 3, 2007 | 10:22 AM
stackz's Avatar
Community Builder
Default Re: (stackz)
anyone know about the yellow circled line???
Old Jan 3, 2007 | 11:22 AM
mike1114's Avatar
yellow most likely needs a vacuum signal.
DO NOT USE HOSE CLAMPS FOR FUEL LINE!!!!!!!!!!!
The pressure will blow them off, possible fire could result.
Find a line at the junkyard that is long enough from a teg or other civic, or order a stainless steel line from someone like Stan at Fast Turbo or others.
Old Jan 3, 2007 | 11:31 AM
stackz's Avatar
Community Builder
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">yellow most likely needs a vacuum signal.
Find a line at the junkyard that is long enough from a teg or other civic, or order a stainless steel line from someone like Stan at Fast Turbo or others.</TD></TR></TABLE>
um, this line is held on with factory hose clamps actually...
it's the fuel return line from the regulator.
Old Jan 3, 2007 | 12:47 PM
Andres-eh2's Avatar
look for a helms manual to check the vacuum.
EGyoke
May 8, 2012 02:45 PM
haroldthefly91crx
Sep 27, 2007 08:49 AM
xxxmikenicexxx
May 22, 2005 07:34 AM
SpyderZEX
Aug 23, 2003 08:09 PM
