Auto Ecu For Hondata???
Old Jan 2, 2007 | 11:51 AM
teg01type-r's Avatar
Default Auto Ecu For Hondata???
i have a P28 ecu for an auto. and my question is can you use this for a hondata S100, ive been told that you can as long as you take out the automatic part of the ECU and i know someone who chips then and i know they can do it but i want to make sure it will work with Hondata. thanks in advanced
Old Jan 2, 2007 | 12:13 PM
advert's Avatar
http://hondata.com/ecus.html
all it says is "Manual transmissions only" so i am not sure if you can just use it and disable the auto part.
hope this helps at least a lil
Old Jan 2, 2007 | 12:23 PM
vtec.dc2's Avatar
Default Re: Auto Ecu For Hondata??? (teg01type-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg01type-r &raquo;</TD></TR><TR><TD CLASS="quote">i know someone who chips then and i know they can do it</TD></TR></TABLE>
in that case, just ask them. it can be done. i do'nt know the details though
Old Jan 2, 2007 | 02:15 PM
slofu's Avatar
pgmfi.org FTW
Old Jan 2, 2007 | 02:37 PM
Relic1's Avatar
remove one resistor, jumper another. it's now a manual trans ECU.
I've done it more times that I can count and never had a problem with any of them.
Old Jan 2, 2007 | 03:07 PM
charlie powerhouse's Avatar
p28 auto will work just fine.
Old Jan 2, 2007 | 08:05 PM
mtber's Avatar
Default Re: (Relic1)
You can use the auto p28 with hondata.
Who ever prepares your ecu simply has to remove rp18 and rp17 and jump rp18.
Old Jan 3, 2007 | 03:20 AM
Default Re: (mtber)
thanks for all the info, thats exactly what i needed to know.
chinochanginc
Engine Management and Tuning
Oct 20, 2008 12:56 PM
h23prelude
Mar 16, 2008 10:15 AM
redlineintegra
Mar 8, 2004 06:31 PM
LudEcrous
Apr 15, 2003 03:54 PM
accordfreak
Oct 31, 2002 07:21 AM
