Door harness pin extraction
Old Jan 2, 2007 | 05:48 AM
LeonardDB's Avatar
Default Passenger Door power windows harness pin extraction
96 Civic LX, 4 door. A couple of wires are loose on the power windows/locks wire harness coming from the body and attached to the door. Anybody know how to extract individual pins from the electrical connector? There are 8 pins and they are flat. I poked around but could not figure out how to get the pins to come out. I'd like to solder the wires and re-insert the pins.
Modified by LeonardDB at 7:24 AM 1/2/2007
Old Jan 2, 2007 | 06:57 AM
eg6sir-s's Avatar
Default Re: Passenger Door power windows harness pin extraction (LeonardDB)
there should be a gray harness where the pins insert too. that harness has a clip that holds down all the pins. pop that off and you can pull out all the pins individually.
Old Jan 2, 2007 | 09:49 AM
LeonardDB's Avatar
Default Re: Passenger Door power windows harness pin extraction (eg6sir-s)
Thanks for the reply eg6sir-s. I've spent hours on this problem. I examined the grey connector that inserts into the door jamb. I popped off the green mounting shroud. The only movable item I could find on the grey connector is a white insert on the side. I had to break this up to pry it out. There are 4 rows of pin cells (5 pins per row, 20 possible pins). Only the top two rows are used. The white insert that I broke up seems to be alignment cells in the center of the grey connector. I stopped breaking it up after I finished breaking up the inner cells for the unused pin cells. I don't see any other clip on the grey connector. Am I missing something?
Old Jan 3, 2007 | 03:24 AM
LeonardDB's Avatar
I got a used harness section from a Salvage Yard for $20.00. I really don't want to do the hack cut and solder technique. Does anyone have a vendor, part number for a tool that can be used to remove the pins from the grey harness connector?
ashtonallen
Mar 12, 2015 05:44 PM
blueBB4lude
Jun 1, 2014 03:56 PM
azndough
12
Mar 2, 2012 09:57 AM
Terry36
May 8, 2011 04:22 PM
Micemt
Dec 4, 2007 11:04 AM
