No spark on a 94 civic
Old Dec 31, 2006 | 11:08 AM
rhiannonsboo's Avatar
Default No spark on a 94 civic
i have a 1994 honda civic dx with a 1.5 non v-tec i was driving it at about 55 mph and it started missing bad so i started to pull over and it died as i puled over. i checked my plug wires and one was loose so i reconected it but it still wouldent start so i towed it to my house and pulled the distributor cap off and it was in bad shape inside so i replaced the cap and rotor and it dident fix it so i checked all fuses and the ignition coil and i have power at the coil and theare were no bad fuses
im stumped on what to do plz help
Old Dec 31, 2006 | 11:13 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: No spark on a 94 civic (rhiannonsboo)
maybe the ignighter
Old Dec 31, 2006 | 12:49 PM
boostdcivicgsr96's Avatar
Default Re: No spark on a 94 civic (Throwdown)
any friends you could borrow a distributor from to try and see if thats the problem, your distributor may have went out on you... good luck man
Old Dec 31, 2006 | 12:53 PM
Paprika's Avatar
Default Re: No spark on a 94 civic (boostdcivicgsr96)
I have a 92 DX also my man, I haven't had a firing problem as you described but I know it may not be easy to ask people if you can borrow their distributor :-p unless it's not on the car at all.
I'd hit the flow charts in the factory service manual, they helped me when my car had an electrical issue because they'll take you through every single possible issue that could be causing the car to not start it's a pretty good chance you'll find the answer.
just a suggestion tho, good luck with this. I have my own storm myself too
Old Dec 31, 2006 | 01:01 PM
MJ0LNIR's Avatar
Check grounds? I think I've seen like five threads in the past month where it was the grounds (I'm ashamed to admit one of them was mine ).
1badcrx
May 9, 2009 12:58 AM
Panoply
Nov 21, 2006 10:15 AM
spunky424
Nov 7, 2004 06:17 AM
JDMBB2
Jan 25, 2004 09:17 AM
CivicBoi
Jul 12, 2002 08:57 AM
