Voom?
Old Dec 31, 2006 | 10:33 AM
actionfigure's Avatar
Default Voom?
I just arrived at home and parked my car. The engine was still on.
The engine sounded like i was pressing the gas and then letting go. Again and again.
Like someone was riviting it up. VOomm......VOOooommm VOoooom.
So I decide to check it in the morning since it was late. So I warmed it up and its not doing the Vooom. Now it runs little rough and I hear soft boom sounds. Its not really a knocking. Sounds like small combustion noise at random.
I asked my friends and they think its the ECU or a Fuel Senor problem.
Please Help.
94 Honda Civic Manual
Old Dec 31, 2006 | 10:43 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Voom? (actionfigure)
start with cleaning out the TB and iacv.. see if it changes anything also see if you have any VAC leaks
Old Dec 31, 2006 | 12:43 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by actionfigure &raquo;</TD></TR><TR><TD CLASS="quote">Like someone was riviting it up. VOomm......VOOooommm VOoooom.
l</TD></TR></TABLE>
sorry i cant resist: ive never seen somebody mess up saying revving or vroom... wow!
Old Dec 31, 2006 | 01:25 PM
Default Re: Voom? (blinx9900)
LOL... sorry Im still learning
Anyways, I was told it was the intake manifold gasket.
Now I need to learn how to replace it or they will charge me $450.
Can anyone point me anywhere?
Thanks!
Old Jan 1, 2007 | 11:10 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by actionfigure &raquo;</TD></TR><TR><TD CLASS="quote">LOL... sorry Im still learning
Thanks!</TD></TR></TABLE>
Get a second opinion, first off the throttle body takes at most, 30 minutes to take off. The gasket is around $30 if that much from Honda. So your getting taken for a ride, and its probably not even the gasket. Spray some bubble water around the throttle body to see if you can spot any air rushing in.
Old Jan 1, 2007 | 12:41 PM
Syndacate's Avatar
Your butterfly in your throttle body was probably just stuck, I wouldn't worry about it, if it concerns you that much, clean the throttle body.
Old Jan 1, 2007 | 04:21 PM
Default Re: (Syndacate)
THanks for everyones advice. I greatly appreciated it.
I detached the IACV and looked at the filter/gasket. It was clean.
I dont think I have enough knowledge to take and clean a TB.
Anyone in the Los Angeles Area that can train this noob?
Thanks
Old Jan 1, 2007 | 04:28 PM
EX-T's Avatar
Default Re: Voom? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Get a second opinion, first off the throttle body takes at most, 30 minutes to take off. The gasket is around $30 if that much from Honda. So your getting taken for a ride, and its probably not even the gasket. Spray some bubble water around the throttle body to see if you can spot any air rushing in.</TD></TR></TABLE>
That's a good way to confuse him! He said intake manifold gasket not throttle body gasket.
OP: I would definitely start by cleaning the throttle body, IACV and intake manifold with some carb cleaner. It's just a few bucks at the parts store. Also check for vacuum leaks because they usually cause an engine to rev and drop, rev and drop.
Edit: You don't have to take the throttle body off to clean it. Just spray it off with some carb cleaner.
Boostn B20
35
Nov 23, 2008 07:40 PM
hmongxcuz
Oct 16, 2008 10:51 AM
red cup
Honda Civic (2001 - 2005)
16
Mar 28, 2008 04:55 AM
thekleenexman
10
Jan 2, 2008 07:03 AM
kurzsi
Feb 13, 2005 12:03 PM
