LS is leaking oil from all around the head
my ls is leaking oil all around the head and its only got 65k on it soo its not a worn our motor but i replaced the head gasket and the spark plug gaskets and still no fix when i drive hard with it and then open my hood i see oil all around the head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o0oz »</TD></TR><TR><TD CLASS="quote">i think...... if you clean out the oil n have somenoe run da car for you... u should be able to find where da oil is coming from...</TD></TR></TABLE>
and sometimes even you replace the headgasket, it might be the gasket alignment problem.
Has the motor ever been overheated? I ask this becasue your problem could be coming from one of several issues:
-warped head (not likely, but is possible)
-the fact that you may need to simply retorque the headbolts
-didn't install the head correctly (possible, but I will assume that you installed it correctly)
-there may be an oil plug or something that blocks oil that may have rotted out (very unlikely that some freakish problem like this occured)
How do you know for SURE that the oil isn't draining down from something else? Cam seals, distributor seal, etc? By the way, is it coming from the timing cover side of the head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integragsr »</TD></TR><TR><TD CLASS="quote">its probably the cam seal even if it dont look like it the oil will leak down and follow the head lines</TD></TR></TABLE>
my money is there...
TheSwift1
Oct 14, 2004 10:20 PM
