has anyone had experience or used this wideband kit
I'm in the market for one for my turbo D and I came across this.
http://www.plxdevices.com/products_SMAFR.htm
has anyone used it before?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyK20 »</TD></TR><TR><TD CLASS="quote">I'm in the market for one for my turbo D and I came across this.
has anyone used it before? </TD></TR></TABLE>
Never used it personally but from what I have heard the PLX devices are very good.
I know, they have a great reputation.
It looks easier than normal to connect it to the ecu so I can datalog the af/r using cromepro.
PLX Widebands are top notch. I do believe you need to still get the guage for that sensor though. That box is merely a control module.
But he said he wants it for CromePro. The very least you need for that is an acurate 0-5V wideband input to where the stock o2 sensor wire is. CromePro w/datalogging cable will do the rest.
I would suggest the M-300 though. It has the display, the narrow and wideband output, and is one of the cheapest kits with a display and the cheap to replace VW sensor.
With the SM-AFR, you have to assemble the power plug as well as pin the wire(s) into the 4-pin connector for the analog output(s). It's more work to install than just the typical (3) wires to the ECU for 12VDC+, GND, and analog output to D14.
Good kit, I'm going to pick one up with the gauge display as well. I've heard a lot of good things about PLX, the supra/rx-7 communities swear by them!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led »</TD></TR><TR><TD CLASS="quote">PLX-M300 here...
I've had nothing but sucess with mine.
Same here plxm300 for me I have had it for 4 years now and it still works like brand new
-James
</TD></TR></TABLE>Same here plxm300 for me I have had it for 4 years now and it still works like brand new
-James
showtymers619
Oct 14, 2007 11:03 PM
