Rear wheel wobbles...
Old Dec 29, 2006 | 05:12 PM
.I.Need.Money.'s Avatar
Default Rear wheel wobbles...
What is causing my rear wheel to wobble?
I had it lifted up today and I noticed there is a lot of play with the left wheel and not with the right.
Something has to be broken....
It's a 93 EG, and yes the lug nuts were on tight.
Old Dec 29, 2006 | 05:15 PM
bart2546's Avatar
Default Re: Rear wheel wobbles... (93EGB18C1)
Wheel bearing. If you have play, it's the wheel bearing.
Old Dec 29, 2006 | 05:19 PM
schardbody's Avatar
Default Re: Rear wheel wobbles... (bart2546)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">Wheel bearing. If you have play, it's the wheel bearing. </TD></TR></TABLE>
i concur.
Old Dec 29, 2006 | 05:32 PM
Well, it's almost like it's wiggling from the arm it's connected to.
Maybe it is a wheel bearing. I dunno.
Old Dec 29, 2006 | 06:00 PM
EG2Driver's Avatar
wheel bearing or messed up bushings maybe? Look where its "wiggling" from
Old Dec 29, 2006 | 08:42 PM
Farmer Brown's Avatar
Default Re: Rear wheel wobbles... (DeadEnd9009)
could be wheel bearings or tierods depending on whats moving.
Old Dec 30, 2006 | 06:26 AM
bart2546's Avatar
Default Re: Rear wheel wobbles... (Djaric)
It's the rear wheel right? So no tie rods there (unless I'm missing something important) Could be a bushing but honestly there's not much to the rear wheels. Brakes, nut to hold the wheel on, lug nuts, and wheel bearing. I'm guessing wheel bearing if it's not the center nut holding the wheel on.
Old Dec 31, 2006 | 01:06 AM
A friend of mine said it was my upper control arm.
Old Dec 31, 2006 | 02:58 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">A friend of mine said it was my upper control arm.</TD></TR></TABLE>
Your friend's an idiot.
Old Dec 31, 2006 | 06:51 AM
bart2546's Avatar
Default Re: Rear wheel wobbles... (IslandSi)
If it's the rear wheel that wobbles, there is NOTHING back there, it's just a wheel that spins because it has to.
Old Dec 31, 2006 | 08:28 AM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">If it's the rear wheel that wobbles, there is NOTHING back there, it's just a wheel that spins because it has to. </TD></TR></TABLE>
there is an upper trailing arm, lower trailing arm, and a few other parts that are wearable items and can cause this problem.
Old Dec 31, 2006 | 08:43 AM
pdiggitydogg's Avatar
Worn arm bushings would cause the entire trailing arm to move, not just the wheel/hub.
Bad wheel bearings tend to make that side wail like a banshee while youre driving down the road. Its very loud, deep, and very annoying.
Im on board with wheel bearing. I just changed mine late summer - its VERY easy.
Old Dec 31, 2006 | 08:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">It's the rear wheel right? So no tie rods there (unless I'm missing something important) Could be a bushing but honestly there's not much to the rear wheels. Brakes, nut to hold the wheel on, lug nuts, and wheel bearing. I'm guessing wheel bearing if it's not the center nut holding the wheel on. </TD></TR></TABLE>
whoops. Rear wheel. Half asleep posting &gt; my reading.
Old Dec 31, 2006 | 09:47 AM
schardbody's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Worn arm bushings would cause the entire trailing arm to move, not just the wheel/hub.
Im on board with wheel bearing. I just changed mine late summer - its VERY easy.</TD></TR></TABLE>
i agree, if it wobbles up/down/side/side its a bearing, if it just has slop one way or the other it could be a few things, point is, ITS NOT HARD TO JACK THE CAR UP AND INSPECT THE FEW COMPONENTS BACK THERE.
Unphzd
Dec 17, 2010 01:10 PM
Tim2179
Jul 13, 2005 01:13 PM
poppycock
Aug 27, 2004 09:58 PM
GSxRated
Aug 3, 2002 08:44 AM
nugget8000
Sep 24, 2001 02:08 PM
