GSR block????
Old Dec 29, 2006 | 04:40 PM
hondachris1994's Avatar
Default GSR block????
What is a going rate price for a GSR block(1.8)used?
Old Dec 29, 2006 | 04:46 PM
EK FLY's Avatar
Default Re: GSR block???? (hondachris1994)
depends u want a bare block , no pistons no crank , like 300 $ , if u want like with crank and pistons , oilpan and **** is like 500 $ for obd1 and like 700 for obd2
Old Dec 29, 2006 | 06:16 PM
I have a b16(obd1) in my hatch now, I wanna buy a gsr block and put my B16 head on it, so it doesnt matter if the gsr block is obd-1 or obd2 correct?
Old Dec 29, 2006 | 07:06 PM
EK FLY's Avatar
Default Re: (hondachris1994)
well as long as ur running ur obd1 computer , u should be fine , bc obd2 gsr motors came with the crank sensor in the oil pump or something , in the oil pump , but if ur running ur obd1 ecu should be good ,
or u can change the oil pump to a 94 gsr
Old Dec 31, 2006 | 02:44 PM
I have a b16a2 in my car now and thats a obd2 motor but im runnin obd1, so changing blocks should b no problem
Old Dec 31, 2006 | 02:52 PM
JDM-EJ1's Avatar
Default Re: GSR block???? (super-hatch)
Completely depends on the situation and what you're buying.
Old Dec 31, 2006 | 04:13 PM
Default Re: GSR block???? (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Completely depends on the situation and what you're buying.</TD></TR></TABLE>What do u mean by that, im buying a 94-01 gsr block
Old Dec 31, 2006 | 04:40 PM
trrbl1bmx's Avatar
I'll sell you a b16 block and you can bore/stroke it out to 1.8 possibly more if you want, and it will probably cost you less!!
Old Dec 31, 2006 | 04:41 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">What do u mean by that, im buying a 94-01 gsr block</TD></TR></TABLE>
Situation meaning.. How in need of cash the guy is you're buying it from. What all comes with the motor. What condition the motor is in? These are all variables.
Old Dec 31, 2006 | 07:03 PM
Situation meaning.. How in need of cash the guy is you're buying it from. What all comes with the motor. What condition the motor is in? These are all variables.</TD></TR></TABLE>Im just gonna buy a GSR block and I not really concerned with condition, cause ima tear it apart and rebuild it with new internals<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n &raquo;</TD></TR><TR><TD CLASS="quote">I'll sell you a b16 block and you can bore/stroke it out to 1.8 possibly more if you want, and it will probably cost you less!!</TD></TR></TABLE>I'll already have a b16 block I could do that, but to bore it out to a 1.8, I would have to sleeve it, so no it wouldnt b cheaper
Old Dec 31, 2006 | 07:05 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">Im just gonna buy a GSR block and I not really concerned with condition, cause ima tear it apart and rebuild it with new internal</TD></TR></TABLE>
What I was referring to is how the cylinder walls are, etc.
Old Jan 1, 2007 | 05:01 AM
What I was referring to is how the cylinder walls are, etc.</TD></TR></TABLE>Yeah im deffinately gonna check everything over before I buy 1 because I dont want 1 with a cracked sleeve or spun bearing
Old Jan 1, 2007 | 10:52 AM
b16a2civicesi's Avatar
i cant see any good reason why sum1 wud hav1 lying around without a head un less it is faulty, so be carefull wat u buy
Old Jan 1, 2007 | 11:13 AM
Default Re: GSR block???? (b16a2civicesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a2civicesi &raquo;</TD></TR><TR><TD CLASS="quote">i cant see any good reason why sum1 wud hav1 lying around without a head un less it is faulty, so be carefull wat u buy</TD></TR></TABLE>salvage yards do, and ppl who mess there heads up, as long as it doesnt have a cracked sleeve or spun bearing, its good enough 4 me cause ima rebuild it anyways
Old Jan 1, 2007 | 12:01 PM
mooseknuckle's Avatar
300 bux
Old Jan 2, 2007 | 01:21 PM
Default Re: GSR block???? (mooseknuckle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mooseknuckle &raquo;</TD></TR><TR><TD CLASS="quote">300 bux</TD></TR></TABLE>Im hopin I can find a decent block for around $500
Old Jan 2, 2007 | 01:46 PM
EK FLY's Avatar
i BOUGHT LIKE 4 BLOCKS ALLREADY 2 of them in really good conditions one of them a jdm R block wich was 300 complete but oil pan , i had to aling hone it and new bearings , wich was good I SPEND ABOUT 200 on the parts and machine works not bad I end up paying for a jdm R block about 500$ ,wch is a good price
Old Jan 2, 2007 | 02:54 PM
robble36's Avatar
building a poorman's type R gsr block b16 head haha
Old Jan 2, 2007 | 04:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch &raquo;</TD></TR><TR><TD CLASS="quote">i BOUGHT LIKE 4 BLOCKS ALLREADY 2 of them in really good conditions one of them a jdm R block wich was 300 complete but oil pan , i had to aling hone it and new bearings , wich was good I SPEND ABOUT 200 on the parts and machine works not bad I end up paying for a jdm R block about 500$ ,wch is a good price </TD></TR></TABLE>damn where did u find someone to sell u a type r block so cheap?
Old Jan 2, 2007 | 05:16 PM
JDM-EJ1's Avatar
Where did you get that figure from?
Old Jan 9, 2007 | 11:33 PM
ive seen that deal quite a bit out here in NJ. as a matter a fact i know a guy up the street selling one.. might grab it myself..
Old Jan 9, 2007 | 11:34 PM
gezzuzz's Avatar
why did you bump this post it for last year
delusionracer
Oct 7, 2008 02:40 PM
Turbo-GSR1287
Apr 12, 2008 08:20 AM
standinghollow
Oct 14, 2005 12:53 PM
blu3g
Aug 9, 2005 04:31 PM
Civic
Dec 14, 2003 11:51 AM
