Anyone make a 7/16"-24 -4an .035" oil restrictor in stainless steel?
Old Dec 29, 2006 | 01:38 PM
Sprockets's Avatar
Default Anyone make a 7/16"-24 -4an .035" oil restrictor in stainless steel?
I'm just curious if anyone has come across this fitting. ATP has them in brass, and Slowboy in aluminum. I found another guy that sells an inline -4an oil filter with a built-in restrictor. It doesn't sound like a bad idea, but it's .8mm, which is smaller than .035". Also, if no one sells stainless, then are there other people who make them?
Old Jan 1, 2007 | 09:34 AM
Sprockets's Avatar
Default Re: Anyone make a 7/16"-24 -4an .035" oil restrictor in stainless steel? (Sprockets)
Anyone know?
Old Jan 1, 2007 | 11:39 AM
HiProfile's Avatar
My question would be why does it have to be stainless? Brass has no problems with most chemicals, and aluminum is fine with gas & oil. My home-made steel/solder restrictor is fine, as the solder is good to 500 degrees. If your motor oil is hitting 400+ outside the block, you've got other problems.
I'd suggest taking the typical brass or steel fitting, soldering/welding it shut, then drilling that size hole in it. Assuming you cleaned the brass first and used flux, there should be no issues.
Old Jan 1, 2007 | 05:46 PM
akira712's Avatar
Default Re: Anyone make a 7/16"-24 -4an .035" oil restrictor in stainless steel? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">My home-made steel/solder restrictor is fine, as the solder is good to 500 degrees. If your motor oil is hitting 400+ outside the block, you've got other problems.
So you just soldered shut a steel fitting? as in with a soldering gun?
Old Jan 1, 2007 | 07:37 PM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">My question would be why does it have to be stainless? Brass has no problems with most chemicals, and aluminum is fine with gas & oil. My home-made steel/solder restrictor is fine, as the solder is good to 500 degrees. If your motor oil is hitting 400+ outside the block, you've got other problems.
I'd suggest taking the typical brass or steel fitting, soldering/welding it shut, then drilling that size hole in it. Assuming you cleaned the brass first and used flux, there should be no issues.</TD></TR></TABLE>
I'd rather pay the $22+ shipped that ATP wants for a brass fitting than buy the properly sized fitting, have it welded shut, then drill a hole. I buy stainless if it's available. Every fitting in my oil line setup is stainless, including the tees. Brass is OK, but turns green eventually.
Evilparadize
Mar 8, 2008 08:19 PM
HickamHatch
Jul 27, 2006 07:00 PM
SM00TH976
May 17, 2006 08:59 AM
jdm-ray
Jul 2, 2005 09:29 PM
Pfieff
Mar 7, 2004 02:08 AM
