very disappointed at comp test results
Old Dec 28, 2006 | 11:16 PM
eg6_rick's Avatar
Default very disappointed at comp test results
well i just did a compression test on the beater and was not very happy at all. here are the results:
cy 1: 0-5 psi
cy 2: 150 psi
cy 3: 155 psi
cy 4: 150 psi
of course the reason why i did this was the timing belt snapped on me about a month ago while idling at about 2k rpm in park and i just replaced the t-belt and the other belts.
i have two questions for you guys: would it be best if i pull the head and inspect it and if valves are burned etc. have it rebuild?? or avoid this route cause i have a feeling cy 1 piston rings are fried and mind as well consider the motor toast and look into swaping with another...any ideas.
edit: beater is an auto 93' accord with 169xxx and f22a6.
Old Dec 29, 2006 | 12:30 AM
philadd's Avatar
Default Re: very disappointed at comp test results (eg6_rick)
if your timing belt snapped, most likely you have some bent/broken valves. i'd check the valves before anything else. The good news is that replacement f22 motors are cheap from the junkyard...
Old Dec 29, 2006 | 12:40 AM
mtnwkr's Avatar
Default Re: very disappointed at comp test results (philadd)
Do a wet test first..
Old Dec 29, 2006 | 02:18 PM
Screaminz28's Avatar
Even though its probable that you bent or broke a valve, do the easy stuff first. I'd check valve lash on the cylinder with no compression. My friend "knew" he had a motor with bad rings, so he re-ringed a motor and cranked it up and it had the same problem. Adjusted the valves and it was perfect, except for all the oil it uses now, cause he used a ghetto bead honer on a drill, lol.
Old Dec 29, 2006 | 03:02 PM
hondaccord's Avatar
Default Re: very disappointed at comp test results (mtnwkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtnwkr &raquo;</TD></TR><TR><TD CLASS="quote">Do a wet test first.. </TD></TR></TABLE> best bet to figgure out if it is the block or valves.
Old Dec 29, 2006 | 03:20 PM
hondadude's Avatar
The best thing to do is bring the engine to #1 TDC and then put compressed air [50 psi or so] in thru the spark plug hole, then you can listen for air escaping out the intake or exhaust. Also while it is at #1 TDC you can pull the valve cover and see if one of the rocker arms has way too much clearance.
I doubt the rings in #1 cylinder are any worse than the rest of the engine, and 150 PSI is not to shoddy for those miles.
If it was my deal, I'd not hesitate for a second to pull the head and replace any bent valves, and retouch the valve seats with the cutter.
Old Dec 29, 2006 | 04:21 PM
eg6_rick's Avatar
Default Re: very disappointed at comp test results (hondadude)
how do i check for valve lash on the cyclinder and for valve clearance??
Old Dec 30, 2006 | 08:51 AM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6_rick &raquo;</TD></TR><TR><TD CLASS="quote">how do i check for valve lash on the cyclinder and for valve clearance?? </TD></TR></TABLE>
Open up your service manual and go to the section that deals with VALVE ADJUSTMENT.
RTFM
Old Dec 30, 2006 | 01:53 PM
hondaccord's Avatar
never thought of that one, neat trick thanks hondadude
stan xx
Aug 28, 2015 04:29 PM
turboedsupe
Mar 9, 2010 07:04 PM
loc_yaj
Apr 12, 2008 06:45 PM
supabang
Jul 23, 2007 12:47 PM
Shannons52
Jul 14, 2003 07:25 PM
