help..just failed emissions state referee (CA)
Old Dec 28, 2006 | 09:42 AM
deadline's Avatar
Default help..just failed emissions state referee (CA)
why is that i failed the 15 mph emission test but i passed the 25 mph test ?
Old Dec 28, 2006 | 09:52 AM
deadline's Avatar
anyone............ wut can i do..why did i fail 15 mph test ?
Old Dec 28, 2006 | 10:19 AM
deadline's Avatar
bump
Old Dec 28, 2006 | 10:34 AM
Secret Squirrel's Avatar
Default Re: (deadline)
Well you also had a problem with the visual inspection regarding the vacuum lines. What types of modifications have been done to the motor? Need more info about the car.
At 15mph..
The HC and NO levels are 2x what is allowed.
What is your timing set at?
Changes in ECU/Tuning?
Lots of vehicles can display higher measured amounts at low speeds, but that is WAY off where it should be.
Old Dec 28, 2006 | 11:18 AM
thesmogman's Avatar
Default Re: (Secret Squirrel)
You have to look at the O2 left over also.
It seems like the cat was not warm enough. or not working good enough.
Also all of your numbers are high which points to the cat.
Have you changed out the O2 sensor and or cat?
Modified <U>OTHER</U> emissions equipment... Did he inform you what is wrong?
EDITED&gt;&gt;&gt;&gt;X2 He passed the vacuum lines, and the wiring.
What was modified???
Modified by thesmogman at 1:13 PM 12/28/2006
Modified by thesmogman at 1:16 PM 12/28/2006
Old Dec 28, 2006 | 11:24 AM
Seahawk's Avatar
Default Re: (thesmogman)
Other emission related components = modified
Old Dec 28, 2006 | 01:37 PM
deadline's Avatar
dude he said to change out my headers.....i had a carb. # for a VW vehicle ?....BOSAL headers ......d16z6 engine
Old Dec 28, 2006 | 02:36 PM
thesmogman's Avatar
Now how did you do that?
Do you have the reciept for the headers?
Also is there a metal tag on the headers? Dude might have not looked.
What CARB # do you have? I will look it up for you.
Edited: Is it D-381? The one for the VW is D-381-1. If he added the last (1) then he sucks.
Modified by thesmogman at 3:48 PM 12/28/2006
Old Dec 28, 2006 | 05:54 PM
deadline's Avatar
I extended my o2 sensor wiring and thats why he said modified emission component....and carb # says really D-381-1....i think
Modified by deadline at 7:09 PM 12/28/2006
Old Dec 28, 2006 | 07:06 PM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">I extended my o2 sensor wiring and thats why he said modified emission component....and carb # says really D-381-1....i think
Modified by deadline at 7:09 PM 12/28/2006</TD></TR></TABLE>
I didn't extend my wiring, i just cut back on the split loom and retaped and split loomed the part; that combined with the longer wire harness that the NTK 24172 O2 sensor comes with, it not really modified since I didn't splice into any wires.
Old Dec 28, 2006 | 07:32 PM
nihad's Avatar
i live in iowa no emmisisns
zerovandez
Feb 2, 2013 07:28 PM
My_EFsedan
Nov 18, 2009 06:54 AM
budomove
17
Jan 19, 2008 03:46 PM
Daniel
Aug 26, 2003 08:43 PM
94cxhybrid-T
Apr 20, 2003 12:25 AM
