Bad TDC Sensor - ECU retards timing?
Old Dec 27, 2006 | 10:32 AM
dean2's Avatar
Default Bad TDC Sensor - ECU retards timing?
I'm working on a friend's 91 Civic wagon with a 1.5L engine. As far as I know, the car is completely stock. It has a bad TDC sensor. According to the Hayne's and an internet search, this means replacing the entire dizzy. (If that's incorrect, please let me know!)
Anyway, the Hayne's does not tell me what the degree values of the timing marks are. I found that info here. Before looking for the timing mark info, I decided to throw the light on it and check the current timing, figuring I'd use that for the new dizzy. The timing is currently around 8 degrees btdc, not the 18 quoted on the VECI label. The car was warmed up and the timing connector adjuster was jumpered.
So... Is the ECU retarding the timing to be safe until the TDC sensor is replaced? I'm a bit worried that the timing was intentionally retarded at some point.
Thanks for your help.
Dean
Old Dec 27, 2006 | 10:42 AM
Suck my DX's Avatar
Default Re: Bad TDC Sensor - ECU retards timing? (dean2)
well if that sensor is bad it should set off a check engine light which will retard timing...if memory serves correct you might get a 35oo rpm rev limit as well till the code is cleared..
im pretty sure that even with a CEL having the service connector jumped will allow you to set timing,but once you remove the cotter pin/wire/whatever from the service connector the ECU will retard the timing again...replace the dizzy...reset the ecu...and redo the timing...youll be good
Old Dec 27, 2006 | 11:21 AM
dean2's Avatar
Default Re: Bad TDC Sensor - ECU retards timing? (Suck my DX)
Thanks for the help. I'm more familiar with carbs and points than the newfangled computerized stuff.
Dean
racer69
Jul 10, 2007 07:26 AM
b20z2
Aug 8, 2005 11:57 AM
sleeperb16a
Nov 19, 2004 07:32 AM
Nextelbuddy
Mar 30, 2004 10:09 AM
Boostless97Lude
Jan 7, 2003 08:24 AM
