Is it Safe to Turn on ur car, move it, then turn it rigth off w/o warm up / turbo timer?
Old Dec 26, 2006 | 02:07 PM
JDM As It Gets's Avatar
Default Is it Safe to Turn on ur car, move it, then turn it rigth off w/o warm up / turbo timer?
I know when ur NA u dont have to warm up ur car and then let it sit idle after turning it off , but for Turbo i know you have to Let it sit after a drive, and usually warm it up a min before driving it.. but Wondering if i just want to move my car from spot A to Spot B tahts like Feet's away, do i have to Warm it up, move it, then let it sit a min before turning it off? whats the safe way to do this? or if not moving / going very far can u just turn it on, wait like 15 secs, then move it, then turn it off right away? dont want to waste time & gas hah
Old Dec 26, 2006 | 02:20 PM
Mykizism's Avatar
Default Re: Is it Safe to Turn on ur car, move it, then turn it rigth off w/o warm up / turbo timer? (JDM As
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM As It Gets &raquo;</TD></TR><TR><TD CLASS="quote">I know when ur NA u dont have to warm up ur car and then let it sit idle after turning it off , but for Turbo i know you have to Let it sit after a drive, and usually warm it up a min before driving it.. but Wondering if i just want to move my car from spot A to Spot B tahts like Feet's away, do i have to Warm it up, move it, then let it sit a min before turning it off? whats the safe way to do this? or if not moving / going very far can u just turn it on, wait like 15 secs, then move it, then turn it off right away? dont want to waste time & gas hah </TD></TR></TABLE>
nope, just do as you do, with a stock car
Old Dec 26, 2006 | 03:24 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">nope, just do as you do, with a stock car</TD></TR></TABLE> I follow that motto all the time --&gt; Turbo Water coolant lines FTW
Old Dec 26, 2006 | 07:17 PM
1Bar GSR's Avatar
To clarify some things...1
1. You dont have to let your turbo car sit after every drive. That is useless. If you had just boosted the expletive outa your car and pull over to stop it is best to wait a minute before turning it off to let the turbo cool down, but if you are driveing normally and not boosting hard then there is no need to time the car.
2. Now with any car it is good to prime the fuel pump prior to starting and I dont know if it makes a difference, but I let my car sit from a cold start for about 30 seconds just to start. When I move my car say in my drive way I just start it up and move it as you are not actually giveing it more rpms then it would if you were letting it idle.
Old Dec 26, 2006 | 08:40 PM
ngogsr's Avatar
its always good to warm any car turbo or not before driving....., but if youre moving in n out of drive way i wouldnt warm it up n let it cool down
Old Dec 26, 2006 | 09:26 PM
Default Re: (ngogsr)
really? wow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> I follow that motto all the time --&gt; Turbo Water coolant lines FTW</TD></TR></TABLE>
huh i dont get that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngogsr &raquo;</TD></TR><TR><TD CLASS="quote">its always good to warm any car turbo or not before driving....., but if youre moving in n out of drive way i wouldnt warm it up n let it cool down</TD></TR></TABLE>
so just moving in and out of drive way its ok to just turn on and drive and turn off? nice ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR &raquo;</TD></TR><TR><TD CLASS="quote">To clarify some things...1
1. You dont have to let your turbo car sit after every drive. That is useless. If you had just boosted the expletive outa your car and pull over to stop it is best to wait a minute before turning it off to let the turbo cool down, but if you are driveing normally and not boosting hard then there is no need to time the car.</TD></TR></TABLE>
So all this time ive been letting my car idle 1:30 after baby da fck outta it has been wasting gas?
2. Now with any car it is good to prime the fuel pump prior to starting and I dont know if it makes a difference, but I let my car sit from a cold start for about 30 seconds just to start. When I move my car say in my drive way I just start it up and move it as you are not actually giveing it more rpms then it would if you were letting it idle.</TD></TR></TABLE>
ic , yeah me too, a min, then drive it Very slowly, making sure im in -20 HG vac.. but sometimes i reach over 3.5k RPM(going uphill) but my thorrtle is very low so my Vac HG is -15 (out of boost)
B16Civic93
Mar 23, 2005 07:23 AM
mchuang
Jan 12, 2005 10:20 AM
slammin86
Oct 1, 2004 12:46 PM
Rob!
Aug 31, 2004 10:12 PM
pelotudo
Oct 14, 2002 08:43 PM
