installing a blower motor
When I bought my crx no air was comeing out of the vents at all. So when I was doing a wiretuck I hide my fusebox and harness underneith the dash and when I did that I yanked the blower motor out and the black box next to it which I am not sure but think it was for the a/c. Is getting cold out side and I am gonna try to install another blower motor back into it, but I am not sure what I should do about that black box that I took out of it should I buy another one of those to? WHat all will I have to do to reinstall the blower motor? I did try to search alittle, thanks for the help
ok ill help one things is if you pulled one out its just thesame as removal
take the glove box out then look staight theres 1 ten mm take that out then look underneith the blower theres one more then look to the right and up theres another ten take them out and dont forget about two plugs and the cable for you climate control and itll drop right down and put one in the same as removal
your welcome.
p.s if your car did not come with ac that black box needs be put back in
your welcome.
Well once you have the new blower motor you will see where themounting holes are and the two (or three?) electrical connections are.
For the black box you removed you can do either one of two things
1. reinstall the black box, if your not running ac you can open it and remove that radiator looking thing in the box and before installing make sure you plug all the holes so that air does not escape through them.
or
2. i have heard of people going to the junk yard, finding a non ac equiped civic and taking the duct that connects the blower with the heater core/box and installing that instead of the black box.
or
Thinks that helps out alot so I have to go to the junk yard and get a duct because a do not have the box any more unless some one has a blower motor and duct they would like to sell
EscCtrl
Feb 1, 2014 04:22 PM
