96 civic with LS swap HELP PLEASE
Old Dec 24, 2006 | 03:27 PM
modifydaccord94's Avatar
Default 96 civic with LS swap HELP PLEASE
so i bought a 96 civic from my friend for a winter car, it has an LS motor swap with a GSR tranny and its runs and all but wants to die when the RPM's are under 2000. and it goes through gas like a big a$$ V8. anyone know what could be wrong??? any help is greatly appriciated.
Old Dec 24, 2006 | 03:57 PM
fishnfst's Avatar
We need more info.. Compression test #'s overall mileage? Double check all of your vacuum lines> How long has it been running.. The cold start and run could take up to a week or two to relearn the low idle... Any Cel's? Is it missing at low rpm therefore causing it to want to die? Low compression in one cylinder or a bad plug wire could also cause the symptoms you are experiencing...
Old Dec 24, 2006 | 04:02 PM
Default Re: (fishnfst)
oh wow. umm....i honestly couldnt tell you any of that info except the milage. it has 114k on it. it ran really well for about a month then the check engine light came on and it just wants to die if you dont keep it about 2000rpm. i know nothig about engines, the swap was done about a week before i bought it and it ran really well. then everything just started going wrong. i'll try to get all that info you asked for though. thank you for helping
Old Dec 25, 2006 | 06:16 AM
RyanA's Avatar
Default Re: (modifydaccord94)
Confucious say: Check engine codes to see what is wrong.....
Old Dec 25, 2006 | 06:46 AM
vtec4max's Avatar
like they said check compression, check vacuum lines, you can easily have a bent valve too, at 114k that's quite a bit of miles on that belt if it's stock yet, my buddy's gsr timing belt broke at 112K, factory belt. not saying there is something wrong with your belt, it's just an idea for you to check you timing...PEACE
Old Dec 25, 2006 | 07:06 AM
the jdmchop's Avatar
Default Re: (vtec_avenue)
check the cel
probly a iac code hence the stallin
Old Dec 25, 2006 | 01:45 PM
Default Re: (THE JDMCHOP)
whats an iac code? i remember a guy from my last job hooked somethin up to a plug under the dash to find codes and nothing came up. i know the ECU has a switch on it because it was programmed for a supercharged motor but if i flip that switch it runs even worse.
how do i check compression and whether or not the valves are bent?
Old Dec 25, 2006 | 01:52 PM
dont worry about checkin compresion
search on here for a how to: on checkin codes
then when you find out which code you got let me know and we can go from there
if you have a 2timer and a chiped ecu tuned for a blower than that can also not help, but first pull the code and we can go forward from there!
pm me if you need
Old Dec 25, 2006 | 01:53 PM
honestly, i know nothing about motors. im all body and paint and suspension. i'd rather just sell the car. i need money to buy some parts for my accord anyay. unless its a rather inexpensive fix. i apriciate all the help. thanks guys.
Old Dec 25, 2006 | 05:59 PM
hey, it says i cannot use instant messaging on here. do you have AIM?? my aim screen name is modifydaccord.
yea i wouldnt know how to get a code unless i was talked through it step by step. cuz my friend from work did plug in that tool thing thats supposed to bring up codes but it came up with nothing. and yea the ecu is chipped and all sorts of weird. but there is a switch to switch it to the chip and if i switch it to that it runs even worse.
walrus_07
Jan 29, 2010 02:13 PM
poorhonda
Jan 15, 2008 04:06 PM
SiB16A
Jan 9, 2006 07:58 AM
ecks_fourttwo
Mar 17, 2005 06:09 PM
