first turbo setup!!
Old Dec 24, 2006 | 03:00 PM
blwn95civic's Avatar
Default first turbo setup!!
well ive got most of the parts bought for ls/vtec my turbo setup:
2000 gsr head/ported and polished
1999 b18b block/line bored
wiseco 9:1 compression pistons
eagle rods
arp rod bolts
garrett t04e-13 turbo
rev hard stage2 manifold
hks ssqv b.o.v.
tial 38mm wastegate
spearco piping
spearco intercooler
RC 750cc injectors
custom 3" downpipe
turboXS dual stage boost controller
and still got the rest to go, along with a good tuning job i havent really settled for a hp goal yet, i plan to run max boost of 12lbs and min boost of 6lbs, is there anything else in perticular that i might need to help run safely?? or if there's anything that needs to be changed please let me know, its prob gonna be around the middle of january before the car gets put together.... and also is there any well know tuners in the N.C. area?? thanks, Trav
Modified by trav95civic at 4:12 PM 12/24/2006
Old Dec 24, 2006 | 03:15 PM
vtec.dc2's Avatar
Default Re: first turbo setup!! (trav95civic)
what type of hp are you planning to accomplish/?
Old Dec 24, 2006 | 03:19 PM
Default Re: first turbo setup!! (vtec.dc2)
i'd be happy with something around 230-240
Old Dec 24, 2006 | 03:21 PM
bigbadboy's Avatar
don't go by boost levels go by HP levels. if you were only going to do that there would have been no reason to get forged internals and all that good stuff. i would say do 300 low boost and 400 high boost
Old Dec 24, 2006 | 03:31 PM
vtec.dc2's Avatar
i woudln't built internals until you blow the internals.
Old Dec 24, 2006 | 03:32 PM
Schister66's Avatar
Man U FTW
230-240whp on built internals??? That was a huge waste of money.....i'm making over 300whp on stock
Old Dec 24, 2006 | 03:56 PM
Default Re: (Schister66)
well this is my first turbo setup... 230 would be fine... 300 would be better.. im new to forced induction and dont really know wat to expect out of the psi i run and stuff... what kinda of hp are similiar setups making with the stock blocks??? thanks for the input!!
Old Dec 24, 2006 | 03:59 PM
lVlemphizStylez's Avatar
Default Re: (trav95civic)
edit*
Old Dec 24, 2006 | 04:05 PM
Default Re: (lVlemphizStylez)
yes the flange fits... i double checked when i recieved the manifold
Old Dec 24, 2006 | 05:44 PM
doood's Avatar
been there done that
what are you using for tuning?
Old Dec 24, 2006 | 05:53 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i woudln't built internals until you blow the internals. </TD></TR></TABLE>
Only scary part in that is if you break a rod and ruin your head. Then you need to rebuild a block and maybe replace a head.
Old Dec 24, 2006 | 06:14 PM
Default Re: first turbo setup!! (doood)
hondata :D
Old Dec 25, 2006 | 06:06 AM
Schister66's Avatar
Man U FTW
Well my setup is a little different than yours, but my first setup was fairly similar and that made 275whp on stock internals @9psi.
My new setup:
CoreyR T3 topmount
T3/60-1 .63ar
3" DP and exhaust
2.5" charge piping
JRC 8" IC
Tial 38mm WG
Tial 50mm BOV
RC550cc injectors
CromePro on chipped P28
Tuned by DB Performance
shabam
Jun 6, 2009 09:57 AM
jdm inc
Jul 30, 2006 06:23 PM
JDMVTEC
Sep 29, 2003 04:07 PM
mike34655
Sep 24, 2003 03:30 AM
HybridFI
Feb 3, 2002 11:25 AM
