exedy stage 1 clutch problem
Old Dec 23, 2006 | 05:52 PM
Lucky 7's Avatar
Default exedy stage 1 clutch problem
I'm having trouble putting on the pressure plate back onto the flywheel. The pins does not line up. Has anyone encounter this problem before?
Old Dec 23, 2006 | 05:54 PM
dohcVTECeg2's Avatar
Default Re: exedy stage 1 clutch problem (Lucky 7)
did you get the right one for your car?
Old Dec 23, 2006 | 06:12 PM
Lucky 7's Avatar
Default Re: exedy stage 1 clutch problem (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">did you get the right one for your car?</TD></TR></TABLE>
yeah, bought the right one. I've tried spining it to make it fit but its off
Old Dec 23, 2006 | 06:13 PM
JSPECSIR's Avatar
mine was like that keep turning it and trying to put it back down over the pins . keep trying the pins in a diff. hole until they line up. it will be a snug fit the bolts will pull it the rest of the way down.
Old Dec 23, 2006 | 06:20 PM
Mikes2000civicsi's Avatar
Default Re: exedy stage 1 clutch problem (JSPECSIR)
wrong holes,try again
Old Dec 24, 2006 | 12:38 PM
Lucky 7's Avatar
Default Re: exedy stage 1 clutch problem (Mikes2000civicsi)
its the wrong plate. The pins and the holes for the bolts are opposite so even if i line up the pin, i can't screw in the bolts
Old Dec 24, 2006 | 08:05 PM
DVC2008's Avatar
your off by one
Old Dec 25, 2006 | 04:28 PM
JSPECSIR's Avatar
Default Re: exedy stage 1 clutch problem (DVC2006)
im telling you, keep turning and putting it back down itll fit.
Old Dec 25, 2006 | 05:18 PM
byronl's Avatar
yea, keep turning it, i went through the same thing, you'll get it eventually.
B16-CRX
Transmission & Drivetrain
Feb 18, 2011 04:34 AM
Buzzbomb
Apr 18, 2010 04:21 AM
Lucky 7
Dec 24, 2006 01:30 PM
mcaro
Nov 3, 2006 05:55 PM
MyVtec8yourV8
Nov 26, 2004 08:37 PM
