twin disk problems help!!
Old Oct 31, 2006 | 04:49 PM
mcaro's Avatar
Default twin disk problems help!!
i have a twin disk from competition clutch and the flywheel bolts are to long its not clearing my rear main seal plate its hitting it motor wont turn cause of it, should i sand down the bolts a little so it will clear ? what should i do>? has any one had this problem be for? her som pic
Old Oct 31, 2006 | 04:51 PM
Jared's Avatar
you need to grind the rear main support plate
Old Oct 31, 2006 | 04:58 PM
miller's Avatar
Default Re: twin disk problems help!! (mcaro)
put the bolts on a lathe and take off .150
Old Oct 31, 2006 | 05:06 PM
Black DC2's Avatar
Default Re: twin disk problems help!! (miller)
aight thanks 4 d help guys......
Old Oct 31, 2006 | 05:09 PM
mcaro's Avatar
sucks wanted to have the tranny on atleast always something
Old Oct 31, 2006 | 06:09 PM
mike1114's Avatar
Default Re: (mcaro)
ace hardware, buy shorter bolts.
Old Nov 3, 2006 | 06:36 AM
Mikey3000's Avatar
Default Re: (mike1114)
why should any modifications need to be made to have this fit right? does comp. clutch say these modifications need to be made for it to fit?
Old Nov 3, 2006 | 06:43 AM
drintegra's Avatar
Default Re: (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">why should any modifications need to be made to have this fit right? does comp. clutch say these modifications need to be made for it to fit?</TD></TR></TABLE>
Call Comp clutches the least they can do is send you some bolts. Sure there wont be an issue with that unless you are missing a Disc
Old Nov 3, 2006 | 04:58 PM
T Dohc's Avatar
Default Re: (drintegra)
On some motors you have to shave down the bolts to clear the seal and oil pan. I had to on mine per Chris @ CC. I just used a dremel w/cut-off disc and took the ends of the bolts off flush with the back of the flywheel. If you have and question let me know.
Old Nov 3, 2006 | 05:55 PM
qfast817's Avatar
Default Re: (T Dohc)
when i helped install it on a gsr it slightly with the gasket but cleared the oilpan
Lucky 7
Dec 25, 2006 05:18 PM
mcaro
Nov 1, 2006 01:50 PM
EG2Driver
Oct 7, 2006 07:50 PM
citrus3000psi
Feb 10, 2006 08:49 AM
95hbMatt
Apr 13, 2003 09:03 PM
