Eagle rod question. Relates to bearing size.
Old Dec 23, 2006 | 05:32 PM
MotorMouth's Avatar
Default Eagle rod question. Relates to bearing size.
I finished building a b series motor with eagle H-beams, after measuring the the clearances I found that the OEM rods marked with a 3 on the side, have the same big end bore as the eagle rods.
Does this mean that i could use the bearing codes from the block on any rod stamped with a number 3? This would save alot of time but I want to be sure that this wasn't a fluke.
Old Dec 23, 2006 | 06:04 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Eagle rod question. Relates to bearing size. (MotorMouth)
better safe than sorry. mic everything
Old Dec 24, 2006 | 05:53 AM
Finland's Avatar
Default Re: Eagle rod question. Relates to bearing size. (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">better safe than sorry. mic everything</TD></TR></TABLE>
Old Dec 24, 2006 | 09:29 AM
HiProfile's Avatar
Default Re: Eagle rod question. Relates to bearing size. (Mr. Helsinki)
Eagles are supposed to be sized for Honda green bearings, which are middle of the road bearings. If your local stealership is like mine, they won't stock any bearings, so I'd suggest getting a full green set, as well as one larger and one smaller set. For $20 you can get the spares and plastigauge and know it was done right.
Old Dec 24, 2006 | 11:45 AM
ccivic's Avatar
Default Re: Eagle rod question. Relates to bearing size. (HiProfile)
I thought the same-- the numbers matched up for green, so why not use acl's? wrong. clearances were way too tight for me. ended up using acl race bearings all around.
Old Dec 27, 2006 | 06:41 PM
MotorMouth's Avatar
Default Re: Eagle rod question. Relates to bearing size. (ccivic)
good answers, thanks guys.
I do mic everything, and will continue to do so.
Old Dec 30, 2006 | 09:45 PM
Jaker's Avatar
Eagle rods are NOT sized for GREEN bearings. Eagle rods for B18s and D16s are sized as a #3 rod. The B16 rods are sized for a different code (IMSMR). You need to match up the #3 rod code with the corresponding code on the crankshaft to know what size rod bearing to start with. Do you micing from there.
Modified by Jaker at 1:19 PM 12/31/2006
Old Dec 31, 2006 | 01:18 AM
Semnos's Avatar
Default Re: Eagle rod question. Relates to bearing size. (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">Eagle rods are NOT sized for GREEN bearings. Eagle rods for B18s and D16s are sized as a #3 rod. The B16 rods are sized for a different code (IMSMR). You need to match up the #3 rod code with the corresponding code on the crankshaft to know what size rod bearing to start with. Do you micing form there.</TD></TR></TABLE>
true true.
lol Never understood why everyone says the rods are for green bearings .... it's like saying the journal size for the rod on the crank doesn't count when getting bearings for it.
Old Jan 1, 2007 | 12:18 AM
MotorMouth's Avatar
Default Re: Eagle rod question. Relates to bearing size. (Semnos)
Loving the responses guys, I am building another b series with Eagles, all the stock rods are #3.
So far we have ordered bearings based on exactly what is stamped on the block and crank. Its been a breeze, my only concern is that one day I'll get a rod from eagle that has different diameter big end and be seriously screwed.
Thanks, I'll let you know if I burn a rod bearing.
Oh Happy New Years, Man I'm a loser, who does this?
Old Jan 1, 2007 | 10:59 AM
Jaker's Avatar
You still need to check the clearances with at the very least some Plastigauge, and even better with micrometers. There's always a possibility that Honda screwed up and measured a bearing wrong, or put it in the wrong package. The block could also be stamped wrong, or you could have read the stampings incorrectly. There's too much at stake to just trust the numbers without measuring.
JDM_ego2033
Engine Machining & Assembly
May 7, 2018 09:43 PM
KdEj1
Sep 15, 2012 07:12 PM
Fc_v8
Apr 1, 2010 11:20 PM
Pfieff
Mar 24, 2004 12:51 PM
VTC_CiViC
Mar 5, 2004 05:49 PM
