Bearing matching with aftermarket rods??
Ok quick question here.. as I understand, the OEM rods are stamped with the color bearing used on each rod, are the Eagle rods also stamped? And if not, how do you determine which bearing to use?
Banned
Re: Bearing matching with aftermarket rods?? (VTC_CiViC)
nope... standard size... but they are within spec..
check this thread out... https://honda-tech.com/zerothread?id=628073
or pm earl, and he'll give you the low down on both oem and acl bearings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC »</TD></TR><TR><TD CLASS="quote">Wow.. nice reading </TD></TR></TABLE>
if your crank is good you just need standard bearings you can also look into king bearings. good price for them. also the number on the rod with the letter on the crank determines the color you must have a helm's manual to find the color. sometimes the bearings still have the color on the side also check that.
