Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 Civic won't start in cold weather
Old Dec 22, 2006 | 12:35 PM
Di's2001's Avatar
Default 01 Civic won't start in cold weather
Hi I am new to the forum we own a 2001 Civic EX. Its been a good car exept recently during a cold snap the car will not start in the morning when it's cold out out here in AZ that's 25 to 30 F. in the early morning. come back later when its around 50 or so and it starts up fine. there are no warning lites on. HELP
Thanks
Old Dec 22, 2006 | 01:29 PM
toyomatt84's Avatar
Sanji
Ever think of having a block heater installed?
Old Dec 22, 2006 | 03:01 PM
brjhnson's Avatar
Default Re: (toyomatt84)
It is becassue your VTAAAKKKK is not warmed up.
Old Dec 26, 2006 | 08:13 PM
jjmajed's Avatar
Default Re: (brjhnson)
have your battery tested
Old Dec 26, 2006 | 09:27 PM
Tadehi's Avatar
Schumacher '10 WDC
Default Re: (jjmajed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjmajed &raquo;</TD></TR><TR><TD CLASS="quote">have your battery tested</TD></TR></TABLE>
What he said, do you park your car outside?
Old Dec 26, 2006 | 10:14 PM
JDM_ESK1's Avatar
if you are still running the original battery that came with the car in 2001, you're best bet is replacing the battery.
Old Dec 26, 2006 | 10:53 PM
Tadehi's Avatar
Schumacher '10 WDC
Default Re: (JDM_ESK1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_ESK1 &raquo;</TD></TR><TR><TD CLASS="quote">if you are still running the original battery that came with the car in 2001, you're best bet is replacing the battery.</TD></TR></TABLE>
LOL if you have had that same battery for the past 5 years, then all I can say is WOW.
Old Dec 27, 2006 | 06:07 AM
toyomatt84's Avatar
Sanji
Default Re: (Tadehi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tadehi &raquo;</TD></TR><TR><TD CLASS="quote">
LOL if you have had that same battery for the past 5 years, then all I can say is WOW. </TD></TR></TABLE>
Mine's original.
Old Dec 28, 2006 | 11:43 AM
Di's2001's Avatar
NO I don't have the original battery. But I do think that the Honda its very voltage sentsitive. In other words if it gets cold out and the batt drops during the night it won't start It cranks fine just not start. I think the batt may be the problem I am thinking of putting a gel cel batt in what do think? lots of money but maybe the answer.
Old Dec 30, 2006 | 05:36 PM
Ouija's Avatar
Default Re: (Di's2001)
Sounds like a battery. My civic starts right up every morning, and I'm in New England.
Old Dec 30, 2006 | 10:25 PM
briq4's Avatar
Default Re: (Ouija)
Doesn't sound like the battery, if it was the battery it wouldn't turn over like normal, he says he comes back later and it starts fine when the temps are up. If the battery were unable to turn the car over, letting it sit wouldn't change that. Sounds like the opposite of the Accord main relay problem. Do our civics have a main relay that can be affected by the weather?
dohc_profile
Oct 12, 2007 11:32 PM
MooreBoost
Aug 31, 2005 08:53 PM
civictyper96
10
May 15, 2004 12:22 PM
RustyDX
Jan 30, 2004 12:48 PM
stock_civic
19
Nov 26, 2003 10:30 AM
