whats the most WHP anyone has made on a 57 trim?
Old Dec 22, 2006 | 06:23 AM
spoolin turbo s's Avatar
Default whats the most WHP anyone has made on a 57 trim?
a buddy of mine laid down 425whp and 370wtq
anyone laid down more than that?
Old Dec 22, 2006 | 06:27 AM
tony1's Avatar
Default Re: whats the most WHP anyone has made on a 57 trim? (spoolin turbo s)
Did 475 on one last week but ran out of injector. Going to upgrade the fuel system and see how much more we can get out of it. The 475 was at 21psi.
Old Dec 22, 2006 | 06:38 AM
ELSpool's Avatar
I've personally seen the 500whp mark on a 50 trim, mustang dyno. 2.0l b18c.
Old Dec 22, 2006 | 06:43 AM
Default Re: (ELSpool)
i guess this shows that VW 1.8t heads don't flow for **** the numbers above was at 30psi
Old Dec 22, 2006 | 07:10 AM
TREVTEC702's Avatar
Made 447whp on an EVO with 22 psi and 91 octane.
Old Dec 22, 2006 | 07:22 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">I've personally seen the 500whp mark on a 50 trim, mustang dyno. 2.0l b18c.</TD></TR></TABLE>
How high was that pushed on pump gas before switching to race gas?
I'm looking to see how much power I can get out of my SC50 .48 a/r on pump gas. 81.5mm LS/VTEC.
Old Dec 22, 2006 | 07:32 AM
Riake's Avatar
Default Re: whats the most WHP anyone has made on a 57 trim? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Did 475 on one last week but ran out of injector. Going to upgrade the fuel system and see how much more we can get out of it. The 475 was at 21psi.</TD></TR></TABLE>
Can you list the head setup? Seems like a lot of power to me at 21 lbs. Im at 11 lbs and make 300, with a conservative tune, stock block and head b18c1. I was hoping to start a build up real soon with pistons/rods/ maybe a new manifold and im looking for around that horsepower. Thanks
Old Dec 22, 2006 | 09:11 AM
tony1's Avatar
Default Re: whats the most WHP anyone has made on a 57 trim? (Riake)
85mm ls block with type r crank, ported head, edelbrock manifold. Only bad part on that setup is the drag manifold. That was also on E85 fuel.
Old Dec 22, 2006 | 09:19 AM
2point2's Avatar
Subscribed.
I really want to push the 57 trim hard on my H22! my 60fts are loving the characteristics of this turbo and have no desire whatsoever to "upgrade". I want to keep working with it.
Old Dec 22, 2006 | 10:50 AM
tony1's Avatar
Default Re: whats the most WHP anyone has made on a 57 trim? (2point2)
well, 60's aren't really dependant very much on the turbo. I'd definitely use a bigger turbo if you're looking for over 500whp.
Old Dec 22, 2006 | 11:31 AM
narfdanarf's Avatar
my cousin put down about 450whp on 22 or 23ish lbs on a b16 with Edelbrock manifold and GSR cams, stock head otherwise.
Old Dec 22, 2006 | 12:04 PM
Suprdave's Avatar
Default Re: whats the most WHP anyone has made on a 57 trim? (narfdanarf)
I think 455whp @ 26psi on a Peakboost 57trim Kit.
Old Dec 22, 2006 | 01:19 PM
nowtype's Avatar
Default Re: whats the most WHP anyone has made on a 57 trim? (Suprdave)
t04e wheel turbos won't make much over 500whp. Its just a fact of they only flow about 45lb/min. If someone made significantly more power, then I'd assume the dyno corrections were pretty significant.
Old Dec 22, 2006 | 04:09 PM
HiProfile's Avatar
Default Re: whats the most WHP anyone has made on a 57 trim? (nowtype)
A local shop has done a couple 1.8's and 2.0L hondas in a row on SC34's, ranging from stock sleeve/head lv-v's to itr's to sleeved/tall deck 2.0L b16's; I think they got a few good deals on the snails. <U>They were doing 400-420whp on Wisconsin 93 octane at 20-25psi</U>, blowing hot air after that.
They weren't making that sort of torque (to OP) though. The other thing is that honda heads seem to like oversized turbos (they like raw flow), where many other motors love high pressure ratios. I believe it has to do with how the heads flow, and the cam (mainly overlap). If torque falls off soon NA, its usually going to do that w/o a giagantic turbo too.
Old Jan 2, 2007 | 08:05 PM
GT-ER's Avatar
Default Re: (spoolin turbo s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s &raquo;</TD></TR><TR><TD CLASS="quote">i guess this shows that VW 1.8t heads don't flow for **** the numbers above was at 30psi </TD></TR></TABLE>
You are correct, they don't flow as well as a Honda head, but that's not the only reason.
Also consider I have stock head ( and stock cams ) and can only rev to 7,800.
Old Jan 2, 2007 | 08:20 PM
95GSRTT
Guest
Posts: n/a
Default Re: (GT-ER)
only 7800? lol wtf do you think hondas rev out to? Not everyone revs to 10k. Most are no more than 8.5k if that
Old Jan 2, 2007 | 08:30 PM
GT-ER's Avatar
Default Re: (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">only 7800? lol wtf do you think hondas rev out to? Not everyone revs to 10k. Most are no more than 8.5k if that</TD></TR></TABLE>
I know... but I even loose power up there. You don't know how many people I would kill to rev to 8.5K and still produce power.
Trust me... a "well massaged" 1.8T head will only flow CLOSE to what a FACTORY K20 head will flow. That's sad.
Old Jan 2, 2007 | 08:39 PM
TurboJesse
Guest
Posts: n/a
Default Re: (GT-ER)
Never dyno'ed but 133mph traps in a full interior eg with big speakerbox,etc and big (prolly 250lb driver)...maybe 450whp&gt;?
liam821
Dec 21, 2008 11:57 AM
t66crx
Jun 8, 2008 05:15 AM
boostincoupe
Dec 29, 2006 09:35 AM
downeyballz
Oct 7, 2005 10:34 AM
Ri5e
Nov 2, 2003 09:54 AM
