need help with 96-98 civic horn
my horn doesnt work anymore..when i did a u-turn i heard a click somwhere near the steering wheel and now my steering wheel horn doesnt work.. i look at the fuse for the horn and its still good..replug everything nothing happen..i even swap out a new srs reel and steering and airbag...and still doesnt work..someone help me out..everything is all plug up but horn doesnt work?
Here's what I would check:
1. Horn itself
2. Horn relay (Stated above)
3. SRS Reel (Ground the horn wire see if it sounds)
4. ^^ If Above doesn't work try it with just the gray harness that connects to the SRS Reel for the cruise control and the horn. Look for the horn wire and ground it.
1. Horn itself
was the clock spring new or used, if it is used then it too could be bad and you just have to keep replacing it until you get a good one or buy a new one. had the same issue.
used but it works good..it came off my buddy car and his works and mine car doesnt..and we play it back into his car and it still works good..dont know why mine car doesnt work
oo00Burnout00oo
Feb 20, 2014 08:52 PM
Relick!
Mar 29, 2011 01:30 PM
