Polishing aluminum...........
Old Dec 21, 2006 | 07:25 PM
bigbadboy's Avatar
Default Polishing aluminum...........
how would you go abt polishing aluminum that is not smoothed out so to say. like the block and stuff?? how can i get it smoothed out and wat do i need to do it with??
Old Dec 21, 2006 | 09:48 PM
bigbadboy's Avatar
ttt
Old Dec 23, 2006 | 07:56 AM
bigbadboy's Avatar
anyone know anything
Old Dec 23, 2006 | 01:40 PM
Top Ramen's Avatar
Default Re: (bigbadboy)
Polishing a block is a pain. You should start by sanding the really rough places or use a sanding disk on a die grinder. Then you just need to go through several stages of polishing compound, starting with a very aggressive one and ending with a very fine rouge. You will need a die gringer to run the bobs or a flexible shaft that attaches to a bench grinder to run small wheels.
Again, polishing a block is a huge task. I did it once for a project where I polished every last part under the hood and I will never do it again. Better off just painting it.
Polishing smaller aluminum parts is relatively easy and just takes some patience. You need a sturdy bench grinder, some buffing wheels and compound. You can get all of the supplies from Eastwood. Use a different wheel for each compound so that you don't mix them.
my .02.
PissedoffHONDA
May 23, 2008 08:21 AM
jinkenny
Sep 17, 2007 05:07 PM
NuRon
Paint and Body
May 8, 2007 09:34 PM
BlUeHoOdCiViC99
Dec 9, 2005 11:09 AM
