Maybe I could...
Old May 6, 2007 | 12:10 AM
NuRon's Avatar
Default Maybe I could...
I was thinking I can just sand down to the white layer underneath using sanding blocks and then spray it with my paint mixed in a can? Let me know guys, thanks.
Old May 6, 2007 | 09:29 AM
SneezinCD5's Avatar
Default Re: Maybe I could... (NuRon)
Better off using a DA sander on that. You'll be there all day with a block. You wanna take all that off, unless you want the same thing to happen in a short while.
Old May 8, 2007 | 01:08 PM
NuRon's Avatar
Is it really gonna take that much longer with a block? What if I use a coarse grit?
Old May 8, 2007 | 09:34 PM
SneezinCD5's Avatar
I really don't understand why everyone thinks a block is the trick for everything. When sanding filler or final sanding,yes a block is what you need but in your case hit that bitch with a DA and go from there. 80 might be a little much since you really don't have much experience. I would say start with 120 and then work your way up. Just keep checking to see how far you need to go down. You wanna get all of that off though.
eg:R
Apr 19, 2014 08:56 AM
jdmkidd23
Paint and Body
Apr 22, 2008 12:32 PM
Si Integra
May 15, 2004 06:08 PM
Nextelbuddy
Feb 10, 2004 09:23 AM
AGen2integra
Nov 28, 2001 09:02 AM
