rev limiter?
Old May 12, 2002 | 07:26 PM
livent's Avatar
Default rev limiter?
My rev limiter kicks in at 6900 rpm and my v tec doesn't work,Any ideas???
Old May 12, 2002 | 07:32 PM
hatchmobile's Avatar
Default Re: rev limiter? (livent)
do you have any check engine lights on at that time or are you throwing any codes???
Old May 12, 2002 | 07:55 PM
livent's Avatar
Default Re: rev limiter? (hatchmobile)
yes my check engine light is on and i have codes, but it doesn't make sense, code 9 and 14???
Old May 13, 2002 | 01:28 AM
AUSDC2R's Avatar
You should really check the oil and make sure that you have enough in your car. Vtec is activated by Oil pressure and hence, no oil - no Vtec.
Old May 13, 2002 | 06:02 AM
rear_flat's Avatar
Default Re: rev limiter? (AUSDC2R)
yup no oil no v-tec
Old May 13, 2002 | 07:49 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
it would be funny if he turned out to have an LS
Old May 13, 2002 | 11:41 AM
CivicEx95's Avatar
Default Re: rev limiter? (dLo GSR)
Solve the problem with those two codes and the problem will go away.
baggedeg
Honda S2000
Jun 12, 2010 06:21 PM
jrea2008
May 9, 2007 02:56 PM
DohctorVtec
Jan 16, 2007 05:43 AM
Y2A
Nov 4, 2003 07:57 PM
Grengostarr
May 13, 2003 11:47 PM
