VTEC problem...throwing code 22...help please!!!!!!!
Old May 7, 2003 | 06:32 PM
Grengostarr's Avatar
Default VTEC problem...throwing code 22...help please!!!!!!!
ok, i put in my vafc like 3 weeks ago...everything has been fine until last night......it seems like i can engauge into vtec in first and second, but it seems like when i start pulling through 3rd...i can get into vtec, but when i come down in the rpm range, my check engine light turns on, and then i bounce off the rev limiter at like 6800 and vtec doesnt engauge and its code 22....but if i turn the car off, it shuts off and doesnt go back on unless i go up that high..........what the **** is going on.....please help me!!!!!!! thanks
Old May 7, 2003 | 06:48 PM
sa21199's Avatar
Default Re: VTEC problem...throwing code 22...help please!!!!!!! (Grengostarr)
chek your oil
Old May 7, 2003 | 07:00 PM
LegoZ81's Avatar
Default Re: VTEC problem...throwing code 22...help please!!!!!!! (sa21199)
Ditto check oil first
second if you are over 2500 miles change oil something could be starving oil (ie bad filter or premature clogging)
check your wiring third.
Old May 7, 2003 | 07:19 PM
Default Re: VTEC problem...throwing code 22...help please!!!!!!! (LegoZ81)
im gonna check my oil in the morning.......i dont think thats it though.......bump before i go to bed...
Old May 8, 2003 | 04:54 AM
bump bump bump
Old May 8, 2003 | 05:14 AM
LegoZ81's Avatar
so was the oil level ok then???
Old May 8, 2003 | 12:19 PM
oil level was fine....i have no idea what is going on....on the other hand...this morning...i got on the thruway and it pulled to like 120 with no problems...but then about a half hour later...it kicked the check engine light when i went to try again....i dont get it
Old May 8, 2003 | 01:02 PM
Kazz's Avatar
v afc wiring could be the problem i had that happen to me too. Don't tap the vafc to v-tech and check to see if the light doesn't come on. If it doesn't come on then its the wiring on the controller. see if u have to tap off the VTM pressure switch. My englich ain't that good so bare with me
Old May 8, 2003 | 01:51 PM
TerribleOne's Avatar
Default Re: VTEC problem...throwing code 22...help please!!!!!!! (JuuKe_EM)
I threw a 22 and first thought it was a dent in my oil pan (which it very well could have been) so I replaced that (good measure anyways, fairly big dent) then I looked up the code and it said it was the vtec pressure switch, checked all the wires to my vtec pressure switch and they were all fine, replaced the switch ($50) and no more code, the switch had just died, I was having the same exact symptoms as you....check for a dent in the pan (a low oil reading will throw the car into safe mode) and if not that then check to see if all your wiring is ok to the vtec pressure switch. Maybe its something with the vafc but if not this could be your problem...(hopefully not a bad sylenoid
Old May 8, 2003 | 02:31 PM
neo1z's Avatar
Default Re: VTEC problem...throwing code 22...help please!!!!!!! (TerribleOne)
1) the guy above terribleone above me said v-tech. yikes.
Search for a thread by me. Exact thing happened. Exact.
Old May 8, 2003 | 04:18 PM
Default Re: VTEC problem...throwing code 22...help please!!!!!!! (neo1z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">1) the guy above terribleone above me said v-tech. yikes. Search for a thread by me. Exact thing happened. Exact.
What turned out to be wrong?
Old May 13, 2003 | 09:43 PM
Check this area...
Old May 13, 2003 | 10:29 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
same things is happening with me.
https://honda-tech.com/zerothread?id=491294
Old May 13, 2003 | 11:47 PM
.Chris.'s Avatar
Default Re: VTEC problem...throwing code 22...help please!!!!!!! (dLo GSR)
Check the gasket and filter for the vtec solenoid.
FSS13foxtrot
Dec 28, 2007 12:32 AM
jrea2008
May 9, 2007 02:56 PM
chuckieD
Nov 5, 2006 02:07 PM
vtec8804
Oct 20, 2006 07:56 AM
hotdoggies
Apr 11, 2005 04:25 AM
