I have to change my head gasket, What should I use on my boosted B16a2
Old Dec 21, 2006 | 10:05 AM
katoeh2o's Avatar
Default I have to change my head gasket, What should I use on my boosted B16a2
What would be good for boost I am looking to lower my compresion. My motor is stock and has 10.4 to 1. So I will be getting a thicker gasket than stock.
Old Dec 21, 2006 | 11:09 AM
Mugencrxsir1's Avatar
Default Re: I have to change my head gasket, What should I use on my boosted B16a2 (katoeh2o)
no reason to get anything other than OEM honda, nothing out performs a honda headgasket period. Especially with golden eagles copper coating, i would just purschase a headgasket from golden eagle and you won't have any problems.
What HP are you looking to make? Most people usually run around 9:1 compression, but it depends on a lot of variables..........
Old Dec 21, 2006 | 11:32 AM
blaze the chemi's Avatar
I thought the B16A2 has 10.2:1 CR?
I have a B16A with 9.9:1 and I boost to 12psi with an OEM HG. Stick with OEM and you'll be happy.
Old Dec 21, 2006 | 03:57 PM
katoeh2o's Avatar
Default Re: I have to change my head gasket, What should I use on my boosted B16a2 (blaze the chemi)
Sound like good numbers.
My motor Is the JDM one and the compression is a little higher.
So for saftey I thought I sould go with a gasket that will lower my comp.
Old Dec 21, 2006 | 04:46 PM
SPOOLINmatt's Avatar
no, get oem. done
Old Dec 21, 2006 | 04:55 PM
gdh8su's Avatar
Default Re: I have to change my head gasket, What should I use on my boosted B16a2 (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">no, get oem. done</TD></TR></TABLE>
What he said!
Old Dec 22, 2006 | 09:48 AM
katoeh2o's Avatar
Default Re: I have to change my head gasket, What should I use on my boosted B16a2 (gdh8su)
Thats cool with me I love OEM honda stuff as much as the next guy. And bucause my girl freinds dad is a honda mechanic I get 20% off.
Old Dec 22, 2006 | 10:02 AM
RedEj8's Avatar
Im using a HG from autozone i think its Felpro? working great! and was like 30 bucks
Old Dec 22, 2006 | 12:05 PM
b18sihatch's Avatar
its a matter of opinion really..... some will say aftermarket some will say oem but all in all its up to you to decide what you will go with
Old Dec 23, 2006 | 09:34 AM
katoeh2o's Avatar
Default Re: I have to change my head gasket, What should I use on my boosted B16a2 (b18sihatch)
I was looking for some advise about thicker gaskets like the cometic. I comes in .074 I belive it is almost 3 times thicker than my stock one. And if that would be good on my turbo charged civic.
Old Dec 23, 2006 | 01:22 PM
wicked2night's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o &raquo;</TD></TR><TR><TD CLASS="quote"> I was looking for some advise about thicker gaskets like the cometic. I comes in .074 I belive it is almost 3 times thicker than my stock one. And if that would be good on my turbo charged civic.</TD></TR></TABLE>
Exactly what i'd like to know. I wanted to get the cometic to drop teh compression to 9:1 and use ARP head bolts. The motor is stock otherwise.
Old Dec 23, 2006 | 01:32 PM
Topdawgg's Avatar
OEM always used here...
Old Dec 23, 2006 | 01:34 PM
bigbadboy's Avatar
all abt preference. if you feel you need to lower the compression with a bigger hg then do it. at the end of the day its wat makes you happy and feel comfortable in the car.
Old Dec 23, 2006 | 03:49 PM
H.A.R.T B18C1EG6's Avatar
Default Re: (bigbadboy)
OEM
Old Dec 24, 2006 | 03:34 AM
Well i haven't tried anything yet, so nither is making me more comfortable. I can only make up my mind depending on what feedback i get. I'm a bit sceptic about running stock HG, it leaves my compression at 10.2:1 and in a daily driver i could get a bad tank of gas and then what? So i'm thinking that i might be safer with a lower compression, but i can't judge on the relayability of the cometic HG.
So what should i do? Stock motor, arround 230-240whp daily driven and maybe tuned on a high boost at 280-290whp.
Old Dec 24, 2006 | 05:09 AM
DaveF's Avatar
Default Re: (wicked2night)
quit being rediculas....
have you seen the highest hp stock block thread ?
there are people pushin these engines and getting decent life span from them. now im not saying go out and try to make 600 on a stock longblock.
but i do know from personal experiance, you can push these suckers to at least 330hp everyday. rev the ***** off it, and it loves it.
engines love boost.(period)
Old Dec 24, 2006 | 08:29 AM
Tchleung's Avatar
OEM head gasket for sure... The thing alot of people don't realize is, when you change to a thicker, or thinner head gasket, it throws your timnig out so only way to compensate for it correctly is adjustable cam gears if you wanna get the base timing right
Old Dec 24, 2006 | 09:54 AM
katoeh2o's Avatar
Default Re: (Tchleung)
That is a good point about the timming I had not thought about. If you mill the head I wonder if you would have timming issuse as well.
Old Dec 24, 2006 | 02:16 PM
Default Re: (dturbocivic)
Well asuming that the compression isn't a problem, should i still keep the stock head studs? I'm not really sure if that's a good idea. And about the stock block thread, i got pissed at because i mentioned that noone is mentioning for how long do those motors keep running.
EK_EG_DC
Feb 25, 2009 08:39 PM
ProPerformance
Jun 16, 2007 08:25 AM
Toy Civic
Jan 24, 2007 02:04 PM
H22Luda720
Mar 6, 2006 07:13 PM
D16A6Turbo
Dec 1, 2002 06:16 PM
