I have to change my head gasket, What should I use on my boosted B16a2
What would be good for boost I am looking to lower my compresion. My motor is stock and has 10.4 to 1. So I will be getting a thicker gasket than stock.
Re: I have to change my head gasket, What should I use on my boosted B16a2 (katoeh2o)
no reason to get anything other than OEM honda, nothing out performs a honda headgasket period. Especially with golden eagles copper coating, i would just purschase a headgasket from golden eagle and you won't have any problems.
What HP are you looking to make? Most people usually run around 9:1 compression, but it depends on a lot of variables..........
I thought the B16A2 has 10.2:1 CR?
I have a B16A with 9.9:1 and I boost to 12psi with an OEM HG. Stick with OEM and you'll be happy.
Re: I have to change my head gasket, What should I use on my boosted B16a2 (blaze the chemi)
Sound like good numbers.
My motor Is the JDM one and the compression is a little higher.
So for saftey I thought I sould go with a gasket that will lower my comp.
Re: I have to change my head gasket, What should I use on my boosted B16a2 (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt »</TD></TR><TR><TD CLASS="quote">no, get oem. done</TD></TR></TABLE>
What he said!
What he said!
Re: I have to change my head gasket, What should I use on my boosted B16a2 (gdh8su)
Thats cool with me I love OEM honda stuff as much as the next guy. And bucause my girl freinds dad is a honda mechanic I get 20% off.
Im using a HG from autozone i think its Felpro? working great! and was like 30 bucks
its a matter of opinion really..... some will say aftermarket some will say oem but all in all its up to you to decide what you will go with
Re: I have to change my head gasket, What should I use on my boosted B16a2 (b18sihatch)
I was looking for some advise about thicker gaskets like the cometic. I comes in .074 I belive it is almost 3 times thicker than my stock one. And if that would be good on my turbo charged civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o »</TD></TR><TR><TD CLASS="quote"> I was looking for some advise about thicker gaskets like the cometic. I comes in .074 I belive it is almost 3 times thicker than my stock one. And if that would be good on my turbo charged civic.</TD></TR></TABLE>
Exactly what i'd like to know. I wanted to get the cometic to drop teh compression to 9:1 and use ARP head bolts. The motor is stock otherwise.
all abt preference. if you feel you need to lower the compression with a bigger hg then do it. at the end of the day its wat makes you happy and feel comfortable in the car.
Re: (bigbadboy)
Well i haven't tried anything yet, so nither is making me more comfortable. I can only make up my mind depending on what feedback i get. I'm a bit sceptic about running stock HG, it leaves my compression at 10.2:1 and in a daily driver i could get a bad tank of gas and then what? So i'm thinking that i might be safer with a lower compression, but i can't judge on the relayability of the cometic HG.
So what should i do? Stock motor, arround 230-240whp daily driven and maybe tuned on a high boost at 280-290whp.
Re: (wicked2night)
quit being rediculas....
have you seen the highest hp stock block thread ?
there are people pushin these engines and getting decent life span from them. now im not saying go out and try to make 600 on a stock longblock.
but i do know from personal experiance, you can push these suckers to at least 330hp everyday. rev the ***** off it, and it loves it.
engines love boost.(period)
OEM head gasket for sure... The thing alot of people don't realize is, when you change to a thicker, or thinner head gasket, it throws your timnig out so only way to compensate for it correctly is adjustable cam gears if you wanna get the base timing right
Re: (Tchleung)
That is a good point about the timming I had not thought about. If you mill the head I wonder if you would have timming issuse as well.
Re: (dturbocivic)
Well asuming that the compression isn't a problem, should i still keep the stock head studs? I'm not really sure if that's a good idea. And about the stock block thread, i got pissed at because i mentioned that noone is mentioning for how long do those motors keep running.
D16A6Turbo
12-01-2002 06:16 PM
