has anyone tried a step-header
Old Dec 23, 2006 | 03:53 PM
redboost10's Avatar
Default has anyone tried a step-header
just wondering, if anyone has tried a step-header design for their turbo manifold. like stepping down from 1 1/2 or whatever to 1 3/8. anyways, i just through those numbers out there, but you get the idea. using a bigger diamter right out of the head for like the first bend, then stepping down to like an 1/8 smaller diameter for the rest of the manifold. dont be harsh, just something i was wondering if people were doing or have tried.
Old Dec 23, 2006 | 05:18 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
I'd like to know, too.
Old Dec 23, 2006 | 10:26 PM
jDMJeRk's Avatar
In for some answers.... :]
Old Dec 23, 2006 | 10:37 PM
redboost10's Avatar
Default Re: (jDMJeRk)
the way the b16 head is, its so wide down in the port, compared to the exit of the port. its sort of like a double barrel shotgun appreance in a way if you wanna look at it that way.
Modified by redboost10 at 12:51 PM 12/24/2006
Old Dec 24, 2006 | 08:18 AM
HiProfile's Avatar
Default Re: (redboost10)
With a turbo manifold, I'd almost expect you to want the reverse, larger runners after the first bend. Its one method to curb reversion. The larger->smaller method would mostly increase veolocity & backpressure and decrease flow. On turbo manifolds less runner volume doesn't really affect spool time much, not to the extent people think.
Old Dec 24, 2006 | 02:53 PM
redboost10's Avatar
Default Re: (HiProfile)
i started thinking about this, and i think on the intake you would like tapered towards the head, but on the exhaust, like mentioned above, if anything you wanna step the diameter up. i think the intake is a lot more important than the exhaust. the exhaust, the only goal is to get that **** outta there as quick as possible. of course, equal length will be put into consideration. my intake will be tapered, and have circle to oval runners with v-stacks in the plenum. the plenum will also be tapered.
rfelix89
Jun 15, 2012 11:23 PM
DC4 Rasta
Jan 24, 2007 08:07 AM
methos713
Jul 25, 2005 10:22 PM
88crxvtec
Mar 24, 2004 09:51 AM
Whooopasss
Feb 18, 2003 03:52 PM
