just got compression test done
Old Dec 20, 2006 | 09:03 PM
acurateg96's Avatar
Default just got compression test done
i have a jdm gsr motor and finally got the compression checked on it. it read #1 239, #2 225, #3 211, and #4 207. my question is why would it be dropping in that order?
Old Dec 20, 2006 | 10:02 PM
blinx9900's Avatar
Default Re: just got compression test done (acurateg96)
239 is extremely high but good none the less, are you sure you kept the throttle open for the last 2 tests cause there a lot lower... not sure why it would decrease in that order though, may just be a kawinky dink...
Old Dec 21, 2006 | 10:28 AM
Scott_Tucker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurateg96 &raquo;</TD></TR><TR><TD CLASS="quote">i have a jdm gsr motor and finally got the compression checked on it. it read #1 239, #2 225, #3 211, and #4 207. my question is why would it be dropping in that order?</TD></TR></TABLE>
Was the head resurfaced? If it was it is possible it was machined at an angle thus making the combustion chambers progressively small from one side of the block to the other.
Old Dec 21, 2006 | 03:00 PM
coneheadsracing's Avatar
Default Re: just got compression test done (Scott_Tucker)
Did you do the test? How many times was it cranked over for each test. After 5 or so, it'll keep building but slower.
Old Dec 21, 2006 | 06:26 PM
s10cky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott_Tucker &raquo;</TD></TR><TR><TD CLASS="quote">
Was the head resurfaced? If it was it is possible it was machined at an angle thus making the combustion chambers progressively small from one side of the block to the other.</TD></TR></TABLE>
GOOD asumption.
Old Dec 21, 2006 | 07:00 PM
turtleman321's Avatar
also just from cranking it the battery looses power and doesnt have enough juice to pump cylinders 3 and 4 as much.
Old Dec 21, 2006 | 09:16 PM
Default Re: (turtleman321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtleman321 &raquo;</TD></TR><TR><TD CLASS="quote">also just from cranking it the battery looses power and doesnt have enough juice to pump cylinders 3 and 4 as much.</TD></TR></TABLE>
I hope he didn't try to do a compression test with a dead battery. Even so in my experience it should not affect the test much even if the battery is partially discharged. Also, those numbers are pretty high which leads me to believe the head may have been milled.
The problem with the surfaced head may happen if they used one of those belt sander surfacers. Any bias in the weight put on the head will cause the surface to be slightly slanted. This could cause problems with the timing belt riding of the cam gear.
Old Dec 21, 2006 | 10:20 PM
Vilt Innovations's Avatar
those #s seem extremely high, even if heads where milled. you tested with oil in the cyls?
Old Dec 21, 2006 | 11:02 PM
blinx9900's Avatar
Default Re: (Vilt Innovations)
just for comparison my b16b checked in at 230 all across with stock 10.8 compression, i just think the first one is really high.
Old Dec 22, 2006 | 06:32 AM
Default Re: (blinx9900)
You know, I've seen a lot of compression test numbers posted that are that high on here. They seem a bit high but if the engine isn't detonating it shouldn't be a problem. Especially since the purpose of the compression test is to compare the sealing of cylinders relative to each other.
Old Dec 22, 2006 | 04:33 PM
acurateg96's Avatar
how is it extremely high? arent gsr's supposed to be at 240? i took it to a mechanic to get the compression check and also a leak down test. all he said was i needed a valve job, get the head resufaced, and get the head gasket replaced. i havent done nothing to the motor internally. i just got the motor how it was from h motors
LStegMATT
Jan 14, 2008 05:33 PM
xd69
Mar 7, 2006 12:10 PM
ChronicGreenDC2
Jun 24, 2005 09:30 AM
geminis2k
Oct 6, 2003 03:47 PM
mattcalica
Aug 18, 2003 01:05 PM
