Is possible to convert an EG to OBDII?
Old Dec 20, 2006 | 04:19 PM
OTI-'s Avatar
Default Is possible to convert an EG to OBDII?
The swap that im dropping in is a b16a2 its obd2 is there a way to convert the dash harness to obd2? or is there an easier way?
Old Dec 20, 2006 | 04:22 PM
flatblack-h22's Avatar
Default Re: Is possible to convert an EG to OBDII? (OTI)
what model civic? use your civic arness, repin the dizzy, and get a OBD1 alternator and a chipped p28 or p30
Bense's Avatar
I'm sure that it is possible, but it's just not worth it.
Use an obd2 teg engine harness and plug it to your obd1 shock tower harness. you'll have to wire in a few extra things from ecu to teg engine harness. then use your obd1 ecu of choice
Old Dec 20, 2006 | 04:29 PM
HondaPartsHero's Avatar
Technical Hero
-keep it obd1 use a chipped P28 or P30
-OBD1-2 distributor adaptor or swap plugs over from your engines dizzy over to the OBD2's dizzy
-swap the plug over from the alternator from your engine's to the OBD2's
-run the wiring for VTEC solenoid, VTEC pressure switch, and knock sensor
-use your engines fuel injectors unless it is a CX or VX
-if your car is a CX or VX you'll have to do some additional O2 wiring
-relocate your intake air temperature sensor from your intake manifold to your intake arm
Old Dec 20, 2006 | 04:30 PM
Technical Hero
Default Re: Is possible to convert an EG to OBDII? (HondaPartsHero)
or do what he said too ^^^ ha
JdmAcclude
Jan 8, 2012 07:26 PM
alsxe10
10
Sep 29, 2010 07:06 PM
XzzRzzX
Apr 3, 2006 05:44 PM
Radyjr
15
Mar 19, 2005 12:30 PM
RuffRhyno
Sep 27, 2003 10:38 AM
