Need Troubleshooter
My d16y7 wont get spark. I have replaced the distributor and ecu, checked fuses. Im about to send it to a shop but it feels like im missing something, feels like a brain fart. I dont trust other people at shops. Is there a complete troubleshoot for a 2000 civic cx?
how are you checking spark? also where did you get the distributor? and have you checked to make sure the rotor spins when you crank the car? the simplest things are the easiest to miss sometimes.
The car used to missfire during wide open throttle. Replaced plugs wires and rotor. Problem continued. Car died one morning on my way to work, never started ever since.
I have more than a half tank. My ecu is getting power my coil and dizzy are getting power my ignigition is getting power and main relay. Fuel pump primes. I put my spark plug wires on the valve cover and crank, but no arc. But i have all new grounds. Maby my fuel gauge is messed up or something? I will put gas in it tomorrow. Maby i could get it running for some smokey *** burnouts?
Erased codes, plugged in IAT sensor. Getting spark now. But cranking is hard, little smoke out of TB, cranking stops for a sec erratically. Only got it up to 500 rpms once.
adrynalinewhore
Feb 27, 2006 10:29 PM
nwdave
Jun 30, 2004 03:10 PM
ejprimo
Apr 25, 2003 10:20 AM
