92 civic CX Tach Problems
Old Dec 18, 2006 | 07:25 PM
likwidchz's Avatar
Default 92 civic CX Tach Problems
Hey guys, so i have a 92 cx and refrenced this http://www.clubcivic.com/board...97738
Pin A8 appears to be the TACH wire, so i started the car measured voltage off of that pin and using ground as a ref point, reved the engine and it changed,
the question is i have a gauge cluster that when installed does not show tach, and its from a civic with a tach and from what ive read its a direct fit.
does anyone know how i can verify the tach on the cluster dosent work rather then assuming it dosent work?
anyone have any ideas?
Old Dec 18, 2006 | 07:30 PM
I Shot 50 Cent's Avatar
Are you attempting to install a GSR cluster, or a Civic cluster with a tach? From this post it seems you're talking about a Civic cluster but from the link, a GSR.
If its a Civic...it should be directly plug and play as your stock harness is prewired for a tach.
Old Dec 18, 2006 | 07:39 PM
likwidchz's Avatar
Default Re: (I Shot 50 Cent)
Yeah it is a stock civic cluster,
I dont mean to be blunt but if you look further down they have wiring diagrams for the other civics, but it just has pinout info the tach wire to verify i am actually getting a tach signal which is a positive at this point. so it looks as if the tach part is DOA.
Old Dec 18, 2006 | 07:42 PM
Syndacate's Avatar
It's possible that the tach's defective.
Does it move at all?
Old Dec 18, 2006 | 07:45 PM
schardbody's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">It's possible that the tach's defective.
Does it move at all?</TD></TR></TABLE>
hey syndacate, just so you know the definition of "ricer" is someone who installs parts that have NO purpose besides style "whether it be good or bad", so a 600whp civic that has a HUGE wing on the back is still a RICED out civic, just a FAST riced out civic.
Old Dec 18, 2006 | 07:51 PM
likwidchz's Avatar
Default Re: (schardbody)
that would be a negative ghost rider.
I took the tach apart and when i move the needle its really hard to move..
Ill conclude the tach is RIP.
Thanks for the help everyone.
Old Dec 25, 2006 | 10:55 AM
likwidchz's Avatar
blue_flames05
Oct 21, 2008 10:56 AM
WhiteOnRice
Aug 18, 2006 10:31 AM
WhiteOnRice
Aug 12, 2006 12:02 PM
Circuit8
Mar 21, 2003 02:49 PM
hybridreams
Sep 25, 2002 08:25 PM
