assembly lube
Old Dec 18, 2006 | 05:59 PM
4doorcivic16's Avatar
Default assembly lube
im putting my engine together and i wanted to know what assembly lube to use. I herd the regular motor oil doesnt stay for long?
Old Dec 18, 2006 | 07:39 PM
k24em2's Avatar
Default Re: assembly lube (4doorcivic16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorcivic16 &raquo;</TD></TR><TR><TD CLASS="quote">im putting my engine together and i wanted to know what assembly lube to use. I herd the regular motor oil doesnt stay for long?</TD></TR></TABLE>
I use Redline assembly lube. Clevite makes some, etc. If you are going to start the motor right away oil is fine, but if its gonna sit for a bit assembly lube is what you need.
Old Dec 19, 2006 | 08:23 PM
qfast817's Avatar
Default Re: assembly lube (k24em2)
i used the one from pepboys/auto zone
Old Dec 19, 2006 | 11:40 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: assembly lube (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">i used the one from pepboys/auto zone</TD></TR></TABLE>
Yep, the stuff in the little red bottle.
Old Dec 20, 2006 | 10:37 AM
alright ill look any idea what its called
Old Dec 20, 2006 | 01:51 PM
dfoxengr's Avatar
Default Re: (4doorcivic16)
called engine assembly lube , lol
Old Dec 20, 2006 | 07:03 PM
lol thanks
Old Dec 20, 2006 | 07:06 PM
so lazy's Avatar
dude i just use regular oil lol 10w30w but when i had an engine sat i tried out that LUCAS oil it held out pretty WELL..
Old Dec 20, 2006 | 07:41 PM
Scott_Tucker's Avatar
White lithium grease is fine on bearings if the engine is going to sit a while. Engine oil may bleed out. Your cam may require break-in lube, usually molybdenum di-sulphide grease ('moly grease').
What ever you do just make sure you prime it before you light it off. Pull the EFI fuse and crank it over for like 30 seconds so when you fire it, it will have oil pressure immediately.
capcon83
Apr 24, 2017 03:55 AM
J.nguyen
Honda S2000
16
May 19, 2007 09:02 AM
Hwj_33
Sep 1, 2006 09:32 AM
TurboEG6
38
Aug 31, 2006 07:55 PM
sickerhatch
Feb 22, 2005 07:26 AM
