bad misfire/running on 3cyls at low rpm only! (srched)
Old Dec 18, 2006 | 05:21 PM
Coltmorris's Avatar
Default bad misfire/running on 3cyls at low rpm only! (srched)
oh god...here we go again. I resoldered all my wiring at the ecu....and the misfire went away..car ran fine for like 2 weeks...now all of the sudden the problem is back again and this time im not throwing any new codes whereas before i was throwing code 16...also i noticed that the total spudder/misfire will go away once the revs get to like 4500. at low revs under high throttle it sounds like a goddamn motor boat. Yes i replaced allll plugs wires/dizzy is new anyways...again..no codes! thanks
Old Dec 18, 2006 | 06:31 PM
Darrell Bs 10SecEG's Avatar
It can be your rotor in the distributor.Sometimes the screw comes loose and it will misfire like that.Or try another distributor if that doesnt work,If not,try another set of injectors because sometimes the injector locks up and cant squirt fuel nomore or at less often.Good luck bro,Darrell
Old Dec 18, 2006 | 06:34 PM
Also if that doesnt work,try another ECU but see if any of your friends have the same car so U can try there parts out on yours before U spend any money on it.Darrell
Old Dec 18, 2006 | 06:41 PM
xotic_crx's Avatar
Default Re: (Darrell Bs 10SecEG)
Could be the MAP sensor going out, that's what mine did, and it would try to die unless i kept the rpms up
Old Dec 19, 2006 | 05:46 PM
Coltmorris's Avatar
Default Re: (xotic_crx)
well the only thing with this is that it wont ever die itll just idle super low and never stall...did you ever throw a code with your map?
Old Dec 20, 2006 | 06:57 AM
Coltmorris's Avatar
Default Re: (Coltmorris)
Im just so confused because the problem is sooooo on and off and i cant figure out what causes it!...for instance on the way to work on monday..half way there it did it hardcore like major sputter and it was pretty much running on 3 cyls...i didnt do a damn thing to it since then and on tuesday it didnt make a peep the entire trip there and back. Anyone have injectors for sale?
Old Dec 20, 2006 | 09:16 AM
oodie's Avatar
Default Re: bad misfire/running on 3cyls at low rpm only! (Coltmorris)
Same thing happen to me try switching out map sensors.
Old Dec 21, 2006 | 02:34 PM
iheartteal's Avatar
i have the same problem and the only code im throwing is 7 which is tps, but thats because my tps got crushed when i put the motor in. The misfire is only intermittant, if i get on it in 2nd it will start out fine then all the sudden it sputters and i shift into 3rd and it sputters like crazy then i go to 5th and its fine
Old Dec 21, 2006 | 05:14 PM
Coltmorris's Avatar
Default Re: (RideroftheHonda)
i also figured out that its ONLY the 3rd cyl that does it and its ONLY when it heats up
Old Dec 22, 2006 | 05:40 AM
Coltmorris's Avatar
and usually only at low revs! what the heck!!
Old Dec 22, 2006 | 08:32 AM
dbiker207's Avatar
try switching the #3 plug with #4 plug. see if it changes what cylinder does it. im thinkin it might be a cracked porcelin
Old Dec 22, 2006 | 12:12 PM
Coltmorris's Avatar
Default Re: (dbiker207)
k ill give it a shot
Old Feb 9, 2007 | 09:13 AM
LIKKLEbit's Avatar
Coltmorris, Have you solved the issue as yet?
usdm_ED7
Apr 18, 2011 12:44 PM
Godspeedmj
20
Aug 12, 2010 01:22 PM
Suzukii
Mar 1, 2010 08:17 AM
Jwbetley
Mar 4, 2009 01:29 PM
RCjdmDA
Dec 13, 2007 09:48 AM
