Blown D16a6
Old Dec 17, 2006 | 09:00 PM
KansasKev's Avatar
Default Blown D16a6
bought the crx knowing it had a blown motor. NOw what to do with it????
But here are some pics.
Not sure what to do now though. The motor and tranny has 220,000 miles on it. I am not sure if the tranny is bad or good.
I know the crx needs new axles, and a lower cross member(the passanger side wheel is pushed back towards the rear), brake master cylinder and booster.
*I'd like to turbo an A6 or sohcZC. Let me know if you have any suggestions for me!
Old Dec 17, 2006 | 11:05 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: Blown D16a6 (KansasKev)
there's no way to repair that hole. Either get a new motor, or get a new block and rebuild the enitire thing.
Old Dec 17, 2006 | 11:11 PM
crx2nr822's Avatar
Default Re: Blown D16a6 (rukawa1one)
Some JB weld should fix that right up But seriously, get a new block....
Old Dec 17, 2006 | 11:21 PM
VRD^don's Avatar
i remember seeing a block with a hole like that...someone weld a new piece on there..if the sleeves arent damaged..or either turn it into a coffee table..
Old Dec 18, 2006 | 10:10 AM
KansasKev's Avatar
I'm thinking about buying the sohc ZC from HMO, but man shipping kills.
Old Dec 18, 2006 | 10:42 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (KansasKev)
Check out tiger japanese as well, their shipping isn't all that bad. Or the classifieds here.
Old Dec 18, 2006 | 11:17 AM
KansasKev's Avatar
I found a d16a6 local for $300 with tranny. it has 200k, and needs timing belt/water pump replaced. No oil leaks.
Worth it?
Old Dec 18, 2006 | 11:26 AM
Loserkidwac's Avatar
w/ trans i'd say its a decent deal...but I would do a rebuild on it before you drop it in....to give you an idea i sold my 91 CRX Si trans for $180, a6 block for $80, and the head for Ithink $30 or so after shipping all with about 160K miles...so $290
Old Dec 18, 2006 | 12:17 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KansasKev &raquo;</TD></TR><TR><TD CLASS="quote">I found a d16a6 local for $300 with tranny. it has 200k, and needs timing belt/water pump replaced. No oil leaks.
Worth it? </TD></TR></TABLE> No. Offer half of that because it needs work, and the transmission has high mileage.
Old Dec 18, 2006 | 12:30 PM
SloAssHB's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> No. Offer half of that because it needs work, and the transmission has high mileage.</TD></TR></TABLE>
I was gonna sell my a6 swap(axels,ecu,trans,engine) with 140k for $200
Old Dec 18, 2006 | 01:18 PM
Default Re: (SloAssHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloAssHB &raquo;</TD></TR><TR><TD CLASS="quote">
I was gonna sell my a6 swap(axels,ecu,trans,engine) with 140k for $200</TD></TR></TABLE>Well that comes with everything, so I would call it fair.
Old Dec 18, 2006 | 02:39 PM
KansasKev's Avatar
I was also thinking that since I needed axles, tranny, and motor: that maybe a B-series motor wouldn't be a bad idea right about now.
Old Dec 19, 2006 | 08:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KansasKev &raquo;</TD></TR><TR><TD CLASS="quote">I was also thinking that since I needed axles, tranny, and motor: that maybe a B-series motor wouldn't be a bad idea right about now. </TD></TR></TABLE>
If you do that check your local junk yard (U-pull-its are the best) and look for 90-93 Integras, 90-91 would be ideal since they are OBD0 and so is your car but you can convert a 92+ motor to OBD0 or your car to OBD1 to accomidate that option..or if you can find a 90-93 Integra for cheap and have the free parking space you can pull alot of parts off of it for the swap
Old Dec 19, 2006 | 08:54 AM
wiZCo's Avatar
Stouts 'n' Scotch
I second the no. You'll have to rebuild/replace all the seals and gaskets on the engine and bearings/synchros on the tranny. Or at least you should. If you go this route I say just get a fresh SOHC ZC swap for ~$400 from hmotors or tiger japanese.
Old Dec 19, 2006 | 08:57 AM
fireant's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">I second the no. You'll have to rebuild/replace all the seals and gaskets on the engine and bearings/synchros on the tranny. Or at least you should. If you go this route I say just get a fresh SOHC ZC swap for ~$400 from hmotors or tiger japanese.</TD></TR></TABLE>
I think the SOHC ZC is the better deal too.
Old Dec 19, 2006 | 09:29 AM
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote"> fresh SOHC ZC swap </TD></TR></TABLE> Fresh is a relative term for a motor that is still just as old.
Old Dec 19, 2006 | 10:58 AM
KansasKev's Avatar
Default Re: (wiZCo)
The local motor would probably just be temporary untill I have the money for a turbo set-up.
The sohc zc motor and trans from HMO is $395(motor)+150(trans)+$225(shipping)=$770***then I will need to change the timing belt and water pump before I put it in.
Old Dec 19, 2006 | 11:09 AM
wiZCo's Avatar
Stouts 'n' Scotch
You could possibly save some money on the tranny. Take off the old one and crack it open, inspect the bearings and synchros/needle bearings then see if it's rebuildable. I use my stock Si tranny with 270K on it on my DOHC ZC, it's not perfect but it's still good. I cracked it open this summer thinking it was bad but only the bearings needed to be changed, so it was an $80 fix. Just my $0.02. BTW, did you check out http://www.tigerjapanese.com? They usually have lower shipping rates than hmotors (to WI at least, not sure about your state).
Edit: just checked out tiger fro shipping to KS and it's $210
Old Dec 19, 2006 | 11:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Fresh is a relative term for a motor that is still just as old.</TD></TR></TABLE>
I agree. people don't seem to understand that OBD0 JDM motors may have low miles but are still 15+ years old and mostlikely been just sitting in a warehouse with no fluids in them and rotting out seals...if you swap in any used motor it would benifit froma rebuild but atleast do the HG and timing belt...
My opinion is to stay USDM since you will not have to pay the JDM mark up because the a6 block says zc on it....probably find a nice z6 swap locally for the same price if not less than a JDM ZC
Old Dec 19, 2006 | 07:28 PM
KansasKev's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">You could possibly save some money on the tranny. Take off the old one and crack it open, inspect the bearings and synchros/needle bearings then see if it's rebuildable. I use my stock Si tranny with 270K on it on my DOHC ZC, it's not perfect but it's still good. I cracked it open this summer thinking it was bad but only the bearings needed to be changed, so it was an $80 fix. Just my $0.02. BTW, did you check out http://www.tigerjapanese.com? They usually have lower shipping rates than hmotors (to WI at least, not sure about your state).
Edit: just checked out tiger fro shipping to KS and it's $210 </TD></TR></TABLE>
Thanks for the help.
Spoolinls
Other Make Vehicles
27
May 7, 2012 09:22 AM
DrivinVtec
Oct 10, 2007 01:00 PM
methos713
May 30, 2007 10:49 AM
EH2-R
10
Apr 12, 2007 09:45 AM
turbod16y7vtec
12
Nov 25, 2002 08:19 AM
