cylinder walls...need new hone?
well, was looking at some threads yesterday and came upon some cylinder wall topics. So after reading, I decided to go take a look at mine. What do you guys think of this....the block has been sitting for 3 1/2 years...maybe more. I bought it from a buddy, who bought it but never installed it. I finally took it off his hands a couple of days ago. He said the guys who had it before him said the block has less then 800 miles, plus it was boosted...ls-vtec turbo, and the block is sleeved. Well, here's the pics...
Re: cylinder walls...need new hone? (methos713)
if the motor is not in the car yet. i would hone the block, but it looks fine. you should check all clearance on the block over, since the block was built a few years ago.
Re: cylinder walls...need new hone? (eg:R)
yeah, the engine was being put together....humm, would hone'n it get those rust build-up out? Plus those vertical line...what would cause that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">Plus those vertical line...what would cause that?</TD></TR></TABLE>
The pistons scraping the wall.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">Just making sure if it's okay to run it like this boosted or to just hone it.</TD></TR></TABLE>
I'd take it apart, check the clearances, get it honed, then re-assemble it.
Re: cylinder walls...need new hone? (Tippyman)
alrite, any one know what type of piston rings to use? And where to get them? I got std. bore 81mm JE pistons. Sorry for the dumb questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">alrite, any one know what type of piston rings to use? And where to get them? I got std. bore 81mm JE pistons. Sorry for the dumb questions.</TD></TR></TABLE>
IF you use a dingle berry to clean up the walls you can stick w/your stock pistons & rings...BUT if you bore it .5 over you will need to get a new set of pistons/rings.
Re: cylinder walls...need new hone? (ExVtec)
wouldn't you want to use new rings, even if its just a new hone? But for the bearings and stuff...could they just be used or does it have to be new too?
yeah you should use new rings if you overbore or not. try a hone first and see how it cleans up. that last cyl looks kinda rough for just a hone to fix, might have to go .020 over...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">wouldn't you want to use new rings, even if its just a new hone? But for the bearings and stuff...could they just be used or does it have to be new too?</TD></TR></TABLE>
Yes, I just wordded my inital response poorly.
guy_from_nerk
07-28-2013 12:25 PM
sitinduk
09-02-2010 05:08 PM
