ok so we have a problem
Old Dec 17, 2006 | 08:24 PM
ls_efhatch's Avatar
Default ok so we have a problem
we have a 95 civic si......gsr swap......it runs....but hrows some random code.....for one....stock virgin gsr ecu...code 9 and knock sensor.......wont hit vtec.......so we change ecus.......true spoon ecu......code 6.....still no vtec.....no code for it either........
everything is pluged in....
the setup
gsr block
ctr pistons
itr cams
s2 im
stock injectors
intake
header
exhaust
thats all.........
what could be wrong
Old Dec 17, 2006 | 08:26 PM
chrisw85's Avatar
Doesn't the OBDII motors utilize a knock sensor? Do you have it wired up? Cause the wireing harness on teh 95 civic is OBDI....
Old Dec 17, 2006 | 08:28 PM
ls_efhatch's Avatar
not its obd1......everythings obd1 both of em have knock sensors
Old Dec 17, 2006 | 08:34 PM
ls_efhatch's Avatar
anyone have an input
Old Dec 18, 2006 | 01:05 AM
marshun's Avatar
Default Re: (ls_efhatch)
use the gsr ecu and check your wiring
Old Dec 18, 2006 | 07:09 AM
ls_efhatch's Avatar
like i said....everythings hooked up wirings hooked up....stock gsr ecu throws a code 9 and knock sensor
Old Dec 18, 2006 | 07:18 AM
biggdogg's Avatar
i recently did the same swap and there is no knock sensor wiring on the obd 1 harness . you have to wire it in . also check to see if you have the plugs swapped between the vtec solenoid and the gray plug that goes in the side of the head same plug but diff color .
Old Dec 18, 2006 | 11:48 AM
rhd type r's Avatar
all the wiring is plug and play, its an obd1 car, with an obd1 motor, and the stock wiring harness. the knock has been wired in. On the stock ecu we get a knock sensor check, as well as a #6, the #6 has been fixed, now we just get a knock code...with the spoon ecu we get a #9 cylinder pos. sensor...there should be no reason for the codes thrown to change between ecu's that is whats messing with me.
Modified by rhd type r at 6:46 PM 12/18/2006
Old Dec 18, 2006 | 11:55 AM
instructor74's Avatar
Default Re: (rhd type r)
Listen up I will only say this one time the 92-95 si or ex DON"T HAVE WIRING IN THEM FOR THE KNOCK SENSOR. they are wired for vtec but the shoc engine did not have a knock sensor. Here is a link for wiring of the ECU
https://honda-tech.com/zerothread?id=1171263
Old Dec 18, 2006 | 05:53 PM
rhd type r's Avatar
ok so we i found the problem today...short in the knock sensor wire...the spoon ecu didnt throw a check because it was chipped not to. also there was a problem withthe spoon ecu, it throws a cps all the time no matter what its in. thanks for the help everyone...
Old Dec 18, 2006 | 06:58 PM
RotaH8er's Avatar
spoon ecu? real or the chip'd pos from ebay?
Old Dec 18, 2006 | 06:59 PM
I Shot 50 Cent's Avatar
Default Re: ok so we have a problem (ls_efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_efhatch &raquo;</TD></TR><TR><TD CLASS="quote">we have a 95 civic si......gsr swap......it runs....but hrows some random code.....for one....stock virgin gsr ecu...code 9 and knock sensor.......wont hit vtec.......so we change ecus.......true spoon ecu......code 6.....still no vtec.....no code for it either........
the setup
gsr block
ctr pistons
itr cams
s2 im
stock injectors
intake
header
exhaust
thats all.........
what could be wrong</TD></TR></TABLE>
Leave some periods for everyone else man!
You should change the title of the thread too so it can be easily searched for in the future when someone else has the same problem. Have you tried swapping Knock Sensors?
Good luck to you also.
Old Dec 19, 2006 | 02:54 PM
rhd type r's Avatar
its a legit one
Old Dec 19, 2006 | 05:28 PM
marshun's Avatar
different years and trims have little differences in the wiring.
like i said. check your wiring. all you gotta do is use a continuity tester.
the ecu wouldnt throw a code if everything was hooked up like it should be
Old Dec 19, 2006 | 05:29 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Old Dec 19, 2006 | 09:28 PM
Default Re: ok so we have a problem (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">....</TD></TR></TABLE>
HAHAHA I dont knwo why...but I found that hilarious. As a matter of fact...
ahemming06
Mar 30, 2006 03:31 PM
wizzards581
14
Jul 5, 2005 11:03 AM
ddong2lee
Mar 4, 2004 05:06 AM
B18Cej1
11
Aug 23, 2003 04:05 PM
clean99teg
Sep 21, 2002 05:43 PM
